Old 01-23-2009, 01:49 PM
scherp69's Avatar
scherp69 scherp69 is offline
Default Painting firewall question
What would be a good paint to use to paint my firewall? I want to paint the entire firewall area including the upper cowel vent area. I'm debating about using POR15 as I still have almost a gallon of it and I like the way it looks. I would do the chassis coat also so the UV rays don't affect it. Here's a pic of my firewall as it sits now. I'm just in the process of grinding the welds down and cleaning it up. Any advice would be great. Thanks.
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
Old 01-23-2009, 02:03 PM
peetsjunkie peetsjunkie is offline
I would never use por on the firewall. Maybe on the inside of the cabin, but I would never put it on the engine bay. A few wet coats of epoxy should be fine.
Old 01-23-2009, 02:05 PM
rjsjea's Avatar
rjsjea rjsjea is offline
Same color as you plan on painting the body
RobS
71 Demon, AlterK - 4 link GenIII hemi conversion
66 Rambler Classic Wagon, LS conversion -Scott's IFS/4bar-bagged
Old 01-23-2009, 03:21 PM
elitecustombody's Avatar
yep, that actually works
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 01-23-2009, 04:40 PM
68protouring454's Avatar
body color or sem hot rod black or duponts hot rod black single stage.or black base, flat clear
Jake's Rod Shop
Old 01-23-2009, 04:53 PM
awr68's Avatar
awr68 awr68 is offline
I used PPG's version of the stock GM underhood black...and I like it a lot!
Tony
'68 Camaro
