Old 01-30-2009, 05:32 AM
Default Prodigy Customs 4Whl Disc Brake Conversion kits, Only $1000
Prodigy Customs presents our Total Car Disc Brake Conversion Package for F-Body 1967-69, A-body 1964-72, This complete kit provides everything you need to convert yout orinigal drum / drum set up to 4 wheel factory style disc brakes at a killer deal. For only $1000 you get....................
Complete Stock Height Kit Includes 11" Rotors, Loaded Large GM Calipers, Caliper Brackets, Backing Plates, Stock Height Spindles, Hoses with Banjo Bolts, Vacuum Hose with Intake Manifold Fittings, Bearings, Seals, Dust Caps, Spindle Nuts, Spindle Washers, all Hardware, Cast Iron Master Cylinder, Brass Proportioning Valve Kit and a Power Brake Booster.
Complete Rear Disc Kit Includes GM Rotors, Loaded Large GM Calipers, Caliper Brackets & Spacers, Bracket Hardware, Flex Hoses & Brackets, Emergency Brake Cables.
These kits are in stock.
For more information email [email protected] or call Frank at four zero seven 832 1752
Frank Serafine
