Old 02-26-2009, 07:34 PM
brianjw4's Avatar
brianjw4 brianjw4 is offline
Default Tuning for turbo
I'm planning on running a single MP t70 on an 5.3L that I'm putting in my 69 camaro. I've been reading a lot about getting started with tuning and some of the concepts are starting to make sense.
The question I've got is when tuning for a turbo, do you start with the same basics as with the NA setup? Or is the foundation of the tune that much different.
Going with EFIlive, I think.... been looking at HPTuners as well, and will be hooking up a wide band.
Old 02-26-2009, 08:00 PM
johnboy1065 johnboy1065 is offline
I think it's a lot different. In the import turbo world (which I know about) you usually shoot for 11.3-11.5 air fuel ratios while under moderate to high boost.
while off boost while crusing around my car will usually get up into the 15-16 afr range.
Old 02-26-2009, 08:13 PM
forced inductions tune to different parameters than n/a. Less timing under boost, and definitely richer a/f under boost. The tuning isn't necessarily a lot harder, but you have less room for error, so sneak up on it.
Old 02-26-2009, 08:20 PM
brianjw4's Avatar
Thanks guys. I figure I'm probably getting over my head a little bit with the turbo, but I really want to run that setup. Been going back and forth about trying it for a few years now.
Is there a ball park timing while under boost or at least a good starting point?
Old 02-26-2009, 08:27 PM
timing is relative to boost, fuel octane, engine/head design, intake air temps (intercooled or not), etc. For an LS most tuners start in the 16-18 degree range max timing at 10-12 psi of boost. This should be a safe starting point, assuming air temps, a/f, etc. are where they should be.
Old 02-28-2009, 08:55 AM
Pantera EFI Pantera EFI is offline
Default Tuning=EMS choice
I agree with the above statements.
Two items MOST IMPORTANT:
The EMS choice, "degree based" OR "event based" ?
1. Crankshaft ignition or distributed ignition ?
2. The number of teeth on the target wheel ?
3. The ability to "detect" a missing tooth WITHOUT a CAS.
The EGO choice, wide band UEGO.
1. The LM-1 will read 1.0 richer than other brands.
2. The LS-9 UEGO will "read" correct in a high pressure exhaust.
3. Too RICH will "melt" piston tops.
Lance
