Old 03-26-2009, 10:18 AM
Pilot20 Pilot20 is offline
Default Pinion Angle Question
I have a 57 Chevy that I am installing Air-Ride suspension on all corners. On the back I am also installing the 4-link AirBar system. My motor and transmission are setting at 3.5 degrees at ride height. I was planning on setting the pinion angle (front up) also at 3.5 degrees. Is this correct? Because of the low ride height, the back of the drive shaft will actually be a little higher then the front. Does this sound right? Thanks for the help.
Old 03-26-2009, 10:58 AM
Make sure and read the directions. I have the G bar which is the sister of the air bar. The instructions said to install it with 1 degree less angle than the drivline angle for pinioin angle change under hard acceleration. I went with .5 less since mine is driven on the street 95% of the time. So you would be at 3.5 driveline sloping down towards the rear of the car and 3.0 pinion sloping up towards the front of the car. \\ My driveshaft also slope up due to the low ride height. It's fine if your angles are correct.
Old 03-26-2009, 01:46 PM
chicane's Avatar
chicane chicane is offline
Yes... that is fine.
Follow the linky... http://www.markwilliams.com/driveshafttech.aspx
Old 03-27-2009, 06:52 AM
PRRC PRRC is offline
Yep, You will be fine. A Lot of the cars we set up the rear end is a little higher than the trans.
www.paradise-road.com
Old 03-27-2009, 12:51 PM
Thanks. I just wanted to make sure before welding everything up.
Old 03-27-2009, 07:10 PM
The WidowMaker's Avatar
ive got to disagree again. if your pinion is higher, you want to point it down. you cant go off of what you have at your tranny, without measuring all of your working angles. if you have 3.5* down at the tranny, and now your DS points up towards the rear, you now have a WA of greater than 3.5*. check the specs on your u-joints, but most want an angle as close to 1* as possible (without going below), and no more than .5* difference btwn WA's.
for YEARS!!! its been common to match the pinion to the tranny ( \-\ ), but especially with your pinion being higher, you need to be like this ( \_/ ).
you could also raise the rear of you tranny to make its angle less. this would also lower your WA's.
check out this site. it lists the commonly accepted driveline configurations, and (third down) lists your up, down, up configuration as one of the unacceptable.
http://www.vibratesoftware.com/html_...igurations.htm
Tim
"The WidowMaker"
Last edited by The WidowMaker; 03-28-2009 at 11:05 PM. Reason: corrected grammar after a long day :-)
