Old 05-30-2009, 07:37 PM
jcal87's Avatar
jcal87 jcal87 is offline
Default 2006 c6 wheels on a camaro
I'm buying either an Art Morrison front clip or a DSE as many of you already know but i wanna know if i buy some corvette wheels and tires will they work on the camaro?
1968 Camaro Blue
1968 Camaro SS (Sold)
Texas A&M Alumni
Old 05-30-2009, 09:32 PM
jcal87's Avatar
every time i post this none ever responds...
1968 Camaro Blue
Texas A&M Alumni
Old 05-30-2009, 09:52 PM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
What are you asking and with respect to which C6 wheels - standard C6 or Zo6?
Will the wheels work without adapters? No.
Will they rub? I'd ask your vendor. I would think with properly sized adapters standard C6 wheels would probably be okay. Z06's won't work out back without a minitub, and the front may be tight. Again, I'd ask your vendor.
Old 05-30-2009, 09:54 PM
jcal87's Avatar
zo6 front and back and why wouldn't they work without an adapter?
1968 Camaro Blue
Texas A&M Alumni
Old 05-30-2009, 11:15 PM
Mkelcy's Avatar
Wrong offset/backspacing. Have you tried searching on any of this?
Old 05-30-2009, 11:17 PM
jcal87's Avatar
no it seems like it would be to specific to search
1968 Camaro Blue
Texas A&M Alumni
Old 05-31-2009, 12:09 AM
https://lateral-g.net/king/ Payton is a cool dude...betting he'd point you in the right direction. You're going to need wheel some big honking will adapters I can guarantee you that unless you want to run an over width rear end. Your still going to need them up front regardless.
Old 05-31-2009, 10:59 AM
jcal87's Avatar
whats his user name on here because on his page it doesn't give his name or email
1968 Camaro Blue
Texas A&M Alumni
Old 05-31-2009, 12:35 PM
Mkelcy's Avatar
Payton King. He's running (at least on his yellow '69) a 21st Century Street Machine subframe.
Old 06-01-2009, 08:31 AM
Payton King's Avatar
Default Sorry I was away
from the computer since friday.
Anyway, I am running a 21st Centruy sub frame so a C5 Or C6 wheel bolts right up without any spacers. I know DSE designed their sub so you could have a little bit of a lip on the wheel. Call Mark at DSE and he can give you that info. Not sure on the AME sub, but Jack Ass is using one of those and running the ZR1 wheel, which is the same offset as the Z06 wheel, but 1/2 inch wider. May want to ask Charlie or Stielow if they used a spacer up front. On the rear, I am sure they built the rear to the correct width. I am running regular C6 stuff on the rear but had mine built to length. I am running a very small spacer on each side as I did not want it too wide and also be able to adjust the spacers to get the wheels perfectly located in the wheel well.
What I like about using a corvette offset is plenty of great wheels for sale on www.corvetteforum.com
