Old 08-21-2009, 12:31 PM
anton danilovich anton danilovich is offline
Default 500hp 410 Ford Stroker motor Brand New
This is a brand new 500hp 410 Ford Stroker motor. Aluminum heads, forged pistons, engine specs bellow. This cost me $6500 to have build and now we have decided to take our project in another direction. Will sell for $4,500 OBO. This engine has never been fired. Comes with intake manifold, water pump and crank pulley. My loss your gain. Call for details or email me for a build sheet. [email protected] Call with any questions 925-286-5819
$4500 OBO
Engine: 410 Ford
Block Specs:
Block #88 351 Windsor Block
Bore 4.040”
Piston KB Dish
Ring Moly
Rod Forged 6.2” - Eagle
Compression 9.7
Crankshaft Specs:
Crankshaft Type Eagle ESP
Rod Clearances 1~8 .015”
Main Clearance 1~5 .002”
Ring Gaps T- .028 B- .020
Prep Polish/Chamfer/Balance- Computer Spun
Cylinder Head Specs:
Type Aluminum 200cc – Port/Polished
Valves 2.05” 1.6” Stainless Steel
Combustion Chamber Size 63cc
Springs .550 Lift 1.47” Dual
Retainers/ Locks Hardened
Rocker Arms Full Roller 1.6 – Stainless Steel
Push Rods Hardened 5/16”
Studs 7/16” Screw-in with Guideplates
Camshaft:
Type Hyd- USE 302 Firing Order- 1-5-4-2-6-3-7-8
Brand Comp
Grind FS XE274H-10
Lift .512 .512
Duration @ .050 230 236
Adv. Duration 274 286
Misc:
Misc: Double Roller Timing, Dampner,
Oil pump/ Ford Intake / Ford Racing Covers
Old 08-25-2009, 11:13 AM
Default bump bump
bump bump
Old 08-25-2009, 11:54 AM
wiedemab's Avatar
wiedemab wiedemab is offline
Location?
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 08-26-2009, 10:41 PM
Originally Posted by wiedemab View Post
Location?
Northern California, Bay area
Old 08-27-2009, 06:48 PM
Is no one builing a ford here or am i asking to much?
any reasonable offer will be accepted.
thanks guys!
Old 08-28-2009, 03:41 PM
brian mc's Avatar
brian mc brian mc is offline
got any pictures of the motor
what part of nor cal you in
