Old 11-21-2009, 05:03 AM
cfwjr1974 cfwjr1974 is offline
Default 69 Roadrunner Protouring
I have completely gotten out of my element and purchased a 69 Plymouth Roadrunner. Just an itch I have always wanted to scratch!
It seems that the only 3 companies I can find that make PT suspensions for it are, RMS (Alter-k-Tion), XV motorsports, and Hotchkis. I fully realize there are not nearly as many available products as there are for a Chevrolet, but I wanted to make sure that I did not leave anyone out of my search.
Thanks,
Chuck
Old 11-21-2009, 05:51 AM
blown9746 blown9746 is offline
magnum force also
Old 11-21-2009, 06:27 AM
Bakaruda's Avatar
Bakaruda Bakaruda is offline
I hope this will help. I will start with what in my opion is the worst system out there. Magnum Force. This system uses your stock shock mounts and this will cause the inner fenders to move in and close the hood gap. If not keeping the hood from opening. There are plenty of guys you can find on the web that have had and removed these.
Now XV. looks like a very good system. The only down side I can think of is it takes alot of work to install. This would be my second choice.
RMS (Alterkation), I am a little partial to this system. I own one. This system is a complete bolt in system. Very easy to install and lots of adjustment. You can find plenty of very fast and highend cars using this. Most of the Mopars on the Powertour that have a aftermarket suspenion came from RMS. This is just my two cents.
Old 11-21-2009, 08:28 AM
autoxcuda's Avatar
autoxcuda autoxcuda is offline
A stock type system like Hotchkis is very capable.
The fabbed K-members show a lot of extra benefit to someone doing motor swaps in an smaller A-body like a big block or a modern Gen3 hemi. Even a Gen3 Hemi in B-body (Road Runner) my be an issue with a stock K-member, beyond just motor mount adapters.
Steve
68 Cuda Autocrosser
Fall Fling XV
October 30, 2010 Saturday
Woodley Park, Van Nuys CA
350+ Mopars, 175+ swap, midways.
Spring Fling Speed Festival April 2011
5th annual, Willow Springs CA, 40+ Mopars,
Event Video 1 Event Video 2
Old 11-21-2009, 09:12 AM
wedged wedged is offline
+1 . Set up right, it can run with the best of them.
Old 11-21-2009, 09:26 AM
rjsjea's Avatar
rjsjea rjsjea is offline
Upgrade the stock or go with the AlterK. I went AlterK for ease of fitting headers etc....as well as some weight savings (95lbs ish)
Look around and you may find pics of failed aftermarket systems out there, BUT I have never seen or heard of an AlterK failing
RobS
71 Demon, AlterK - 4 link GenIII hemi conversion
66 Rambler Classic Wagon, LS conversion -Scott's IFS/4bar-bagged
