Old 12-05-2009, 04:00 PM
olskooljr olskooljr is offline
Default Lowering a 67Camaro
I want to lower my 67 Camaro. I know I can get 2-inch lowering springs for the front, but I'm not sure about what is the most cost-effective way to lower the rear. Any suggestions? Is it possible with leaf springs or would they need to be converted?
Old 12-05-2009, 07:07 PM
awr68's Avatar
awr68 awr68 is offline
You could use some blocks to lower the rear...but that's not my first choice!
I would use a 2" or 3" drop spring....my choice being the 3".
Tony
'68 Camaro
Old 12-05-2009, 07:29 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
I highly recommend a 3" drop leaf!!!!!!! Seems that everyone that went with the 2" hasn't been happy. When I replaced the ones on the bucket I went with Global West and would recommend them to anyone.
Be sure to post up some before and after pictures for us!
Oh.....what wheels are you running and how wide are they? Maybe you should post up a pic now.
Curtis
Old 12-05-2009, 07:36 PM
Spiffav8's Avatar
Lateral-g Moderator
Ok...I did a search and found some pictures. For sure you need the 3" drop springs. But I suppose that all depends on how low you really want to go. Which front springs are you planning to use?
Here's a pic of the results I got from a 2" drop spring and yes I would have liked it to get just a bit lower.
Hope it helped.
Curtis
Old 12-05-2009, 08:47 PM
dlouie87's Avatar
dlouie87 dlouie87 is offline
Hope it helped.
Curtis,
I was wondering if you can help me out with posting your suspension modification list? I love the stance and I'm trying to figure it out for my 67 too.
-Dan
Old 12-05-2009, 10:17 PM
Spiffav8, thanx for the pics. Yea I think another inch in the rear would be cool. Where can I order 3inch drop leaf springs? And should i go with 2 or 3 in the front? I attached a couple of pics. I was thinking about DSE or ordering something from jegs.
Old 12-06-2009, 11:19 AM
Spiffav8's Avatar
Lateral-g Moderator
Originally Posted by dlouie87 View Post
Curtis,
-Dan
Dan,
No problem.
Global West L2-CAT5 leaf springs
Global West S-13 Front coil springs
Global West upper control arms
Global West sub-frame connectors
ATS Tall Spindles
Bilstien Shocks
Hotchkis sway bars
Now...more importantly what would I change.
If I where to stay with leaf springs I would use the L3-CAT5 springs from Global West and a different front coil spring. One with a higher spring rate. The S-13's are great but I had to trim them to get the ride height I wanted and that caused a minor rub issue on big bumps at higher speeds. Also I do not like the Global West Sub Frame Connectors. I would use DSE or if I did stick with GW then I would recommend using the convertible ones. They do the exact same thing but route a bit different and don't block the spring pocket.
Any other questions??
Curtis
Old 12-06-2009, 12:17 PM
MODO Innovations's Avatar
Hope it helped.
Curtis, this is one of my favorite 67's. Can you post more pics if you have them?
What are the specs on the wheels?
Shannon
Modo Innovations
940-391-9002
Old 12-06-2009, 02:33 PM
Spiffav8's Avatar
Lateral-g Moderator
Sure....sorry not trying to jack your thread olskooljr.
The wheels are iForged "Astra" 18x8 front (5.00" backspace) and 18x10 rear wheels (5.50" backspace) Nitto NT55 tires, 245 wide fronts, 285 rears.
By the way...I am going to need another set of those pedals for my next car.
Curtis
