Old 12-27-2009, 06:10 PM
GM Muscle's Avatar
Default mounts and drivetrain angle
ok ive researched a little and just want to verify some things. help me out guys.
LSX swap into my 69 camaro, i have solid engine mounts and solid body bushings.
Should i also run a solid trans mount?
i was leaning towards yes but this seems to be a mixed reveiw
since the trans mount isnt in yet i can still set the engine angle. from what ive read, anything between -3 and -5 should be ok.
Is this correct?
Also, to measure this angle, im assuming ill set the car to where the frame rails are at zero then point the trans down from there right?
Thanks in advance guys
'69 Camaro- Daily Driver
'70 Chevelle- Project
Old 12-27-2009, 06:23 PM
You need a poly trans mount with solid motor mounts. Personally I wouldn't run a solid motor mount. I hate mine and will be converting to poly when my motor goes back in. GM set the drivline angle at about 4 degrees in 69. Personally I would go with what makes the most sense at your ride height. Meaning level the rockers, get your rear end at ride height and experiment. You can shim the trans up and down easily with a spacer between the mount and trans. Your tunnel clearance will dictate it to some extent unless you modify the tunnel.
Old 12-28-2009, 06:02 AM
dhutton dhutton is offline
I think if you run solid engine mounts with an LSX you will have problems with the knock sensors. Better to use poly engine mounts.
Old 12-28-2009, 06:26 AM
GM Muscle's Avatar
Well I already had a solid setup so it was just cheaper and more convienent. I'll try to find a poly trans mount.
As far as knock sensors... It's carbed
btw. This is a 4l80e if it matters
Old 12-28-2009, 10:25 AM
This whole "angle" debate is very confusing.... and can cause major headaches and issues of drive line vibration to oil starvation...
The reason the motors were set at down angles (from front to rear - rear being down) was to get the drive line angle correct -- and that is some debate anymore as well... and to allow for the pinion angle to rise under heavy acceleration as it wanted to wrap up the leaf springs as it tried to climb the ring gear... (whew! Long sentence!)
David Pozzi has a very good discussion on his website about this - drive line angle/u joint etc. Very worth reading. THE PROBLEM IS AFTER LOOKING NOW I CAN'T FIND IT so maybe I have the wrong site...
Also -- the "new" suspensions (3 link - 4 link whatever) don't allow for the leaf spring wrap-up of the old days... so the pinion angle relationship to the engine angle (used to be - Motor down 3 degrees - pinion down 3 to cancel each other and wind up with zero)... can be set differently - with many now setting pinion angles at 1 degree or zero...
I would also respectfully disagree with leveling the frame or rockers to set these angles - and would instead suggest that the car be at ride height and with the weight on the suspension as it would be on the street. Let's take an example of a way to ruin a good motor.... level the car - then go down 3 degrees on the motor... now you put the car at ride height with "bigs and littles" - and you're rear end is higher than the front and your rockers are now raked nose down 5 degrees.... your motor ends up nose down 2 degrees... with oil running to the front of the pan (in a Camaro lets say with a rear sump)....
I'm always confused by all of this stuff ---- so lets hear the proper way to do this?
Old 12-28-2009, 10:41 AM
70rs's Avatar
70rs 70rs is offline
This is all very interesting to me. I have never had to set up a car like this, and will have to when (if) mine is at that point.
I would love to find out the right way to do this.
What is the proper way to do this with a TKO/T56 and a torque arm rear?
Most pro touring applications are going for a fairly level stance. Most intake manifolds are milled at 4 degrees to level the carburator. To do it in a conventional way, meaning driveshaft on a downward slope, you will need more like 2-3 degrees of driveline slope. With these low ride heights and 4 degrees of angle you can't achieve a downward slope in the driveshaft unless you set the pinion up at an angle not equal to your driveline. Now I agree when setting up corresponding driveline angles, the car being level is not important. My point is simply if you are going with a custom set up you have to start somewhere. I know on my car the rockers are wihin .5 degree of level at ride height. You can always figure that out and take that into account when setting your drivline angle.
