Old 02-11-2010, 07:32 PM
ItDoRun's Avatar
ItDoRun ItDoRun is offline
Default Subframe Cleaning
I just finished welding up the seams on my subframe tonight and was curious the best way to clean and prep the metal for primer and paint. The reason I ask is because some areas have oil soaked in the metal from oil leaks over the years.
Chris
Old 02-11-2010, 10:08 PM
COYBILT's Avatar
COYBILT COYBILT is offline
wax and grease remover or EASY off works well.
1965 GTO convertible
2009 GM Design Award winner
Triple black with Subtle yet massive Modifications.
Old 02-12-2010, 05:06 AM
Send it out for sandblasting. Makes them Sweet!
Frank Serafine
Old 02-12-2010, 05:34 AM
deuce_454's Avatar
what he said!... its the best foundation for paint anyway.. and while you are at it have them powdercoat it... its about the same price as painting wet, and it holds up better.. AND you only have to drop it off.. and when you pick it up its finished!
Jake: Hit it.
Old 02-12-2010, 05:48 AM
elitecustombody's Avatar
agreed, and after that get it powdercoated,most of the time it will be alot cheaper to powdercoat than get it painted
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 02-12-2010, 07:01 AM
ItDoRun's Avatar
I sandblasted it before I started welding on it. After sitting for a couple of days, you can see oil that had seeped from the seams in certain areas. It's mainly contained around the steering box area. As I was welding on it, you could see oil bubbling up because of the heat...not to mention the smoke created from welding!
I had planned on blasting it again before I primed/painted it, but obviously paint won't stick to oily surfaces.
Chris
Old 02-12-2010, 08:24 AM
We paint ours. Powder coat will really show any pits in the surface. painting aloows us to skim, prime, sand and make it more prettier!
Frank Serafine
