Old 02-22-2010, 01:59 PM
Mike69Cam Mike69Cam is offline
Default LS3 dry sump system?
Does anyone know about dry sump systems for LS3? Is anyone making a system? I would think the market is there due to popularity of the '10 Camaro.
Old 02-22-2010, 08:11 PM
GM is putting a "dry sump" on the manual 2010 Grand Sport corvettes. I assume you can pick up the stuff for it from GM direct. Maybe not as good as aftermarket setups but it's something at least.
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 02-22-2010, 08:40 PM
David Pozzi's Avatar
The LS7 crank snout is longer to accept the dual stage oil pump. I wonder if the LS3 with dry sump has a longer crank snout too?
http://www.PozziRacing.com
Old 02-22-2010, 08:57 PM
Thanks...I heard about the OEM dry sump for the new Vette today. Doubt an aftermarket is available yet. I just committed to an AM chassis for my 69 Camaro build. I want to autocross and roadrace it, so dry sump makes sense. Will check out the GM system. Dave...do you and Mary use dry sump in your cars?
Old 03-05-2010, 10:48 AM
chicane's Avatar
chicane chicane is offline
ARE, AVAID and Dailey all make dry sump systems for the LSx series... including simple upgrades to the factory LS7 oil system... all the way to full blown 5 stage unitized pan systems.
ARE's LSx web page
Avaid's LSx catalog
Dailey's LSx web page (Link limited due to web page construction.)
