Old 11-27-2005, 08:54 PM
comp-spec's Avatar
comp-spec comp-spec is offline
Default just starting project.Has to be done for jan 6 world of wheels
Well it is aready sand blasted.But i still have to pre assemble mini tub, ladder bar,coil over,wire f i ,assemble engine, detail ,do some metal work to make it alittle diff ,bodywork, paint complete car inside and out top to bottom,interior,
and have it ready to show on the 5th
Old 11-27-2005, 09:03 PM
What kind f car?
Old 11-27-2005, 09:46 PM
comp-spec's Avatar
68 camaro convert
Old 11-27-2005, 09:52 PM
race-rodz race-rodz is offline
hmmmmmmm, better get a good nights sleep....prolly the last one you will have till jan 6th
Old 11-27-2005, 09:59 PM
comp-spec's Avatar
There will be some long hours coming up
Old 11-27-2005, 10:13 PM
awr68's Avatar
awr68 awr68 is offline
ladder bar? Is this a pro-street car? Just seems that if it's intended to be a nice driver you wouldn't go that route as the leafs would actually be better. Perhaps a 3 or 4-bar is in order?
Good luck with the project and I hope you share lots of pics!!
Tony
'68 Camaro
Old 12-28-2005, 08:28 PM
Blake Foster's Avatar
Hey Comp
Times almost up i hope you have enough time to get-er-done
Oh i guess you wont even have time to respond so no answer is a good answer
good luck
you can return the favor on april 10 as ours needs to be done on the 15th
Old 12-29-2005, 06:12 AM
comp-spec's Avatar
Stang is running a 430 sbf twin turbo hoping to in the 6's in outlaw 10.5 class
Willy's is all steal came in for a color change toyellow was black that car is for the world of wheels too
I'm a little more behind that i want to be right now on the 68 convert but there is still 1 week so im going to go sand and sand and sand ill take to u guys later with some up dates thanks for the luck
Now im hoping to have the car in primer and on all 4 tires ready to paint on monday
Old 12-29-2005, 06:25 AM
J2SpeedandCustom J2SpeedandCustom is offline
As a wish man once told me. "Sand until your balls hurt, then it's done."
Old 01-03-2006, 01:21 AM
comp-spec's Avatar
3:45 am just getting finished ,firewall , block sanded doors, qrts, trunk, + reprime last time
finished the underside prime seamseal + body shultz
get a little sleep
9:00 am back to work block hood + firewall reprime paint subframe+firewall watersand out car base back of doors + hinges hang doors + fenders
base car stripe it clearcoat (hope to be painting be 8:00 pm)
wensday sand+buff ,drop motor in, rear end ,install trim and interoir, convert top ( just next day air complete delux interior)
word of wheels thuresday night
