Old 03-14-2010, 05:26 PM
scherp69's Avatar
scherp69 scherp69 is offline
Default Brake line fittings
I'm going to start the plumbing on my car soon and was looking at ordering some 3 AN fittings. All I can get locally is Russell, Earl's and Aeroquip. Is there one that is better of the three or should I stay away from all three? I also need to get another set of braided lines for the rears, but I don't think that Allstar Performance has a Canadian dealer. I don't plan on racing the car, so would one of their lines be okay? Thanks in advance.
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
Old 03-14-2010, 06:52 PM
Mike ---
Check out where I get most of my stuff....
http://www.purechoicemotorsports.com/
Or
Bent Fab will supply your stuff too! Give Mark a toot... see what he recommends?
Old 03-15-2010, 07:18 PM
scherp69's Avatar
Thanks for the link Greg. I see they have a Canadian dealer also. I see they use Aeroquip for some of their stuff. I can get that locally too. I just need to know if there are any issues with any of the three companies I mentioned.
Mike
New Gen Splitters
LS3 and TKO600
Old 03-15-2010, 07:31 PM
The only thing I would say is "don't mix" the manufacturers -- if you're going Aeroquip hose - use aeroquip fittings.
I've used all three brands you mention... and would not say negative things about any of them... but have found hose size differences - thus the admonition to try no to mix brands up.
Marc at Bent Fab is really the expert on this stuff I would think - and I'm sure he probably has a more "professional" opinion on the brands.
Old 03-15-2010, 08:07 PM
Sti_Guy's Avatar
Sti_Guy Sti_Guy is offline
Yeah I'll second that. When it comes downt to hose ends and hose stay with one brand across the board. For brake line stuff 3an/4an tube nuts, etc you will be find. Personally I like to stay with steel brake line stuff and go aluminum on other fluid connections.
Old 03-15-2010, 08:46 PM
scherp69's Avatar
Right now I have Allstar performance braided lines that came with my brake kit. If I end up going with Aeroquip (haven't made a choice yet, just picking one for the example), should I scrap the Allstar lines and run Aeroquip then?
Mike
New Gen Splitters
LS3 and TKO600
