Old 03-21-2010, 03:29 AM
tyoneal's Avatar
tyoneal tyoneal is offline
Default 2nd Generation Trans Am Steering Wheel Diameter??
To All:
Can someone tell me the diameter of a 1977 Trans Am Steering wheel? I read they gat a bit bigger after 1974 or 75, then in 76 they remained the same until the third generation.
The difference in thickness was a bit of padding.
I am wanting to translate the 13 or so inches, whatever it winds up being to mm's.
Thanks,
Ty
Project, "EnGULFed"
Ty O'Neal
"She Devil" aka. Betty
1969/70 Camaro SS
427 LS3, 600
Keisler Road and Track T-56
"Chester's '65"
1965 Buick Riviera
Old 03-21-2010, 06:54 PM
well, I could have helped you but I'm just ow seeing this post and my car is an hour away. It's small I know that.
Old 03-22-2010, 05:56 PM
takid455 takid455 is offline
the frames are all the same diameter. 70-74 had a thinker foam padding. 75-81 fell thin compared to the earlier wheel. they repop the early wheel. Lecara makes a nice leather substitute. I dont know the numerical diameter off the top of my head.
Old 03-22-2010, 06:16 PM
70rs's Avatar
70rs 70rs is offline
Not sure if the camaro and TA were the same(or even close) but my 70 rs steering wheel is 15 1/8" outside edge to edge. (25mm per inch FYI).
Eric
Old 03-22-2010, 10:33 PM
Musclerodz's Avatar
I think the t/a formula wheel is around 14". The later wheels have a thicker grip
Mike Redpath
Musclerodz & Customz
facebook page
Old 03-24-2010, 02:09 AM
tyoneal's Avatar
Thanks Everyone:
I had one for years and liked it a lot. I'm getting ready to buy one and I didn't want to go to small.
I appreciate ALL your help.
Thanks again.
Ty
Project, "EnGULFed"
Ty O'Neal
1969/70 Camaro SS
427 LS3, 600
"Chester's '65"
1965 Buick Riviera
Old 03-24-2010, 02:35 PM
Default Actual measurements
Went and measure one from a 79 and one from a 74
depending on where I measured, all measurements varied about .0625 or 1/16" roughly
74. same as 70-74
overall dia. 14.25" +/- .0625
thickness of foam. (perpendicular to stitching. ie. front to back of car) - 1.125 +/- .0625
79
same as 75-81 except pace car and 10th anniversary. they follow 70-74 measurements. grey in color.
dia - 14.074-14.1"
thickness of foam. (perpendicular to stitching. ie. front to back of car) - 1" +/- .0625
hope this helps
