Old 04-08-2010, 09:21 AM
g356gear's Avatar
g356gear g356gear is offline
Default Custom Drive Shaft for 69 Camaro
Anyone have a good reputable shop they can recommend for a custom length drive shaft?
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
Old 04-10-2010, 04:43 PM
HotRod68Camaro's Avatar
HotRod68Camaro HotRod68Camaro is offline
I went with a 3" nitrous ready shaft from Denny's Driveshaft.
Kyle
Old 04-11-2010, 08:41 AM
^ X's 2
But you can get a good driveline from most any local shop... which might be "easier" if you need it in a day or two.
The key to drivelines is the USE... critical speed etc - so the shop needs to know that you might be building a high horse - high speed (gears etc) driveline so they can select the tube correctly.
Old 04-11-2010, 05:53 PM
Gregster1234 Gregster1234 is offline
I went with a NASCAR driveshaft which is 4" diameter for use with my TKO 600 and it has the huge 1350 series front C6 yoke and I was able to give the length needed to the inch and they stocked for around $130.00. That was last year. His Ebay store is listed below and he currently has them for $94.00 shipped and they are in 1" increments. These things handle 1000 hp plus!!
http://stores.ebay.com/MuscleMotorSports-Store
Old 04-12-2010, 03:21 PM
wedged wedged is offline
For serious projects I use these guys : http://www.dynotechengineering.com/
