Old 12-05-2005, 02:12 PM
jwillia2's Avatar
jwillia2 jwillia2 is offline
Default which control arms???
are the BMR control arms any good??? I have used their products in the past, but nothing for a 1st gen.... i was think about buying the upper and lowers and getting the QA1's
Ironworks Built 1969 Camaro AKA "HillbillyDLX"
Full DSE suspension LSA T56
Forgeline MonoBlock GA1R OPEN LUG
https://lateral-g.net/members/williams69/
Old 12-05-2005, 02:52 PM
almcbri's Avatar
almcbri almcbri is offline
from what I have learned:
BMR has no increase in geometry, but they are stronger than the stock arms and lighter
I think Detroit Speed, Global West, Speedtech and SC&C arms are awesome arms. SC&C is a cool arm and is adjustable which can give you different changes in your geometry. Marcus with SC&C says the arms are easy to dial in.
Also Hotchkis is coming out with a set of Upper and lower arms in January. I spoke with a guy from hotchkis awhile back and he said the arms will have geometry improvements. He didn't really give any more information other than that.
Lower control arms do not help your geometry from what I am told.
Some guys box their stock lower arms to make them stronger. Or you can go with the tubular for the wow factor. Hope this helps a bit
1968 Camaro LS1/T56, Hotchkis Springs, Tubular Arms, AFCO sway bar, C5 brakes, VWW 18" V40's http://s14.photobucket.com/albums/a3...1968%20Camaro/
Old 12-05-2005, 11:56 PM
zbugger's Avatar
zbugger zbugger is offline
I spoke with John Hotchkis at SEMA, and asked that specific question. His answer is that they were just trying to complete their package and that the arms were just bolt on replacements. No geometry advantages whatsoever.
Old 12-06-2005, 09:53 PM
David Pozzi's Avatar
The Hotchkis upper arms have offset inserts in the shafts like the DSE arms, - to allow more (or less) adjustment, I don't know how much if any extra caster is built into the arms if any. The inserts alone should help some, maybe 2 or 3 degrees extra caster?
http://www.PozziRacing.com
Old 12-07-2005, 02:15 PM
Sue Sue is offline
I just got some from Marcus at SC&C for my 67 camaro.
I think they're the best design at the best price.
my .02
Dave Denysenko
67 camaro
Old 12-05-2005, 03:19 PM
jwillia2's Avatar
cool, that helps.i may wait and see what the hotchkis is like..thanks for the info
Old 12-05-2005, 08:21 PM
check out upper arms from Global West, Speed Tech, and Detroit Speed, they all help you set additional positive caster which helps keep the tires flat in a turn. Lower arms won't change geometry, there are some benefits of easier indexing of the coil spirng, because most have a plastic seat that can be rotated to fit your coil.- if it's cut, it will still sit in the bottom of the lower pocket.
David
