Old 04-23-2010, 01:31 PM
69MyWay's Avatar
69MyWay 69MyWay is offline
Default Got the SHAFT!!!!!!!!!
Man...
Took my 69 Camaro to www.speedinc.com today to do the first live dyno tune since I put the car together. It has been running on a mail order tune since 2005. At that...it ripped a 12.5 at the quarter at 111 on C5 Goodyear runflats. It has carried me 11K trouble free happy miles...and been to the 1/8th mile many times. I am not shy about the throttle either when I'm out of traffic.
With all that said...I found out two things. First...all this time I have only had 85% of my throttle. I wondered why the car laid down a little at the top of the quarter...now I know why.
SECOND - MY DRIVE SHAFT SNAPPED at 6,300 RPM and destroyed the exhaust, some tunnel wiring, and the floor pan.
We rescheduled to finish it up on 5/14 - but I have to obviously fix it by then. I'm also a bit concerned about making the mid west challenge if I don't pull it together.
Funny thing is, I'm not mad about it. I'm glad it happened there...and not anywhere else. I almost drove the car the 150 mile one way trip to the dyno, but opted out as a buddy was giving me some mufflers for my wife's car that wouldn't have fit in the camaro.
Sorry for the long post. Now I have to try to make some lemonade out of the lemons.
Oh...before it broke it put down 362 hp at the rear wheels at the moment of breakage.
Old 04-23-2010, 01:40 PM
n2protour n2protour is offline
was that the original driveshaft or aftermarket one that came as a kit with the tranny? I had the u-joints broke on me long time ago when I did a burnout. Luckily the emergency cable kept the driveshaft from touching the ground.
Old 04-23-2010, 02:00 PM
69MyWay's Avatar
Stock shaft that had been balanced and set to bolt to the 9" axle.
There is no evidence of rust or other damage to it. The trans mount is secure...and there is simply no other explanation.
The dyno guy said that sometimes when there is a little bend or unbalance situation in the shaft they will do this.
The drive line angle is good and I can't imagine the dyno put more stress on it than normal street driving.
Old 04-23-2010, 02:58 PM
Could be that depending on the rear gears and tranny combo -- your old stock shaft hit whats known as it's CRITICAL SPEED.
Do a little research on the subject. I think David Pozzi has some info on it on his website (can't remember). But my guess is that is the cause of the failure.
Old 04-23-2010, 03:45 PM
Rick D's Avatar
Rick D Rick D is offline
Originally Posted by 69MyWay View Post
The dyno guy said that sometimes when there is a little bend or unbalance situation in the shaft they will do this..
And Jim (the dyno guy) has a VERY heavy right foot, and some cool and fast cars!!
Rick
Old 04-23-2010, 04:00 PM
thedude327 thedude327 is offline
362 to the rear wheels is about 452 at the crank. Nice motor. Are you going with an aluminum driveshaft to replace your 2 piece?
Paul
1973 Z28 Street-touring project.........
Old 04-23-2010, 04:24 PM
1969x11's Avatar
1969x11 1969x11 is offline
If you dont mind me asking what are your engine specs, t-56? I'm running a cam only LS1 in my 69 and your got me wondering. Thanks
