Old 05-12-2010, 10:01 AM
RickM415 RickM415 is offline
Default bulkhead fittings -10
so where do i get some hose ends to go to the o-ring -10 on the firewall to my water pump inlet and outlet
i am wondering what type of fitting should i have on my water pump and what size
Rick
1969 camaro rs ss
ls3 twin turbo 6speed will be done when the browns win a Super Bowl lol
Old 05-12-2010, 10:49 AM
camcojb camcojb is online now
do you have pics of what you're working with? Hoses from the pump to the firewall would be heater hoses. The LS pumps have pressed in nipple fittings on the pumps. I remove those and tap them for pipe threads (one is 1/2" NPT and the other is 3/8" NPT). Then I can use a pipe to #10 AN fitting and run my #10 heater hoses to the firewall. I'm confused by the 0-ring fitting you mentioned, all the firewall bulkhead heater hose fittings I've used have had normal male AN ends on them, so any #10 AN hose end would work. The A/C fittings are 0-ring #6 and #10 (others sizes optional) but not the water fittings.
Old 05-13-2010, 12:19 AM
http://www.oldairproducts.com/catalo...e.php?pID=3598
ok i got this from detroit speed /vintage air and it looks like all of them are 0-ring on both sides 3 -10 and 1 -06
Rick
1969 camaro rs ss
Old 05-13-2010, 07:58 AM
yeah Vintage Air gives you AN fittings for the heater hoses. If you go to Old Air's site they sell the heater hose ends, they look just like a/c fittings............. Would have to be crimped onto the hose and you'd be using a non-braided type hose.
Old 05-13-2010, 09:47 AM
thank you Jody
Rick
1969 camaro rs ss
