Old 06-26-2010, 05:58 PM
johnnymac46's Avatar
johnnymac46 johnnymac46 is offline
Default which Miller welder
I am about to buy a Mig welder. My god father who has recently passed was a welder my hole life and swore by Millers. I am looking at a Millermatic 180 Autoset, my question is, will this do everything i need to do. I know i will need to make a cart for my car, it is completely stripped and on jackstands, which makes it hard to move as you all know, and I am going to be installing a AME Rearclip. Will the 180 get enought penetration to weld the frame to the floor pan? i know it will do all the body work i need with out a problem. Im just wondering if i should step up to the 211. I wont be doing much work on thicker metals it will be 97% body work.
http://www.millerwelds.com/products/...c_180_autoset/
http://www.millerwelds.com/products/...c_211_autoset/
Old 06-26-2010, 06:34 PM
coolwelder62's Avatar
I think the 180 will work fine for this type of work.Ask your local welding supply mgr. if they have a demo you could try out over the week end.Tell him you are going to buy one or the other.If they want to make a sale they should let try it over the week end if you leave a deposit.Good luck Scott.
Old 06-26-2010, 07:00 PM
ma73z's Avatar
ma73z ma73z is offline
Can't go wrong with miller in my opinion, I just got a 211 on Friday I liked the ability to use 110 or 220 which I have used several times with my plasma cutter, either way I think you will be happy.
Old 06-27-2010, 06:51 AM
Mikael A Mikael A is offline
I have the 211 and i love it. figured out what you need it for then buy the next step up from there.
Mike a
Old 06-27-2010, 08:40 AM
Always go bigger on a welder. I own a 210... Miller. I'm a Miller kind of guy - but that doesn't really make any difference.
What you will find out about owning a welder - is that there are LOTS AND LOTS of things you can do with it... and your friends will have projects etc... so for the lousy $100 difference between the smaller machine and the larger - go larger 'cause the last $100 is insurance on the first $1000 that you'll have a machine that can do it when needed.
Owning a welder - and being good with it - is like owning a pickup... "you be da man" (when your friends need you).
Old 07-03-2010, 12:42 PM
Scott Hightower's Avatar
Scott Hightower Scott Hightower is offline
Default Bigger is Better
Bigger is Better if you can spend the extra cash. However, the 180 has plenty of power for your project.
Fab Manager
Welders360
Old 07-03-2010, 02:07 PM
deuce_454's Avatar
bigger is better... a big heavy used welder will outperform a new one dollar for dollar....
i borrowed a 400 amp ESAB MIG welder the other day, and it just put down a bead that looked almost like it was tigged
Jake: Hit it.
Old 07-04-2010, 10:02 AM
David Pozzi's Avatar
Compare duty cycle, when you get on a big job on thick metal where you really turn the welder up and weld a longer time, the smaller welder will turn off when it get's hot. Duty cycle is the number of minutes you can weld out of every 10 minutes. A 5 min duty cycle is 50% duty cycle.
98% of the time you won't need many amps to do the job, but if I could upsize for only $100 or so. I'd do it.
David
http://www.PozziRacing.com
Old 04-30-2011, 12:55 PM
I know im a little late but thanks for the help deciding on a welder i went with the 211 MVP it works awesome.
The auto darkening helmet was a great investment as well. I would highly recommend getting one to any one who welds.
Old 04-30-2011, 01:08 PM
Nice!
Personally -- I HATE my Miller Elite helmet. I'm older... as in DIRT OLD... and many times (light gauges etc) it just won't be light enough for me.
I almost always use my OPTREL or my Speedglass.... they'll adjust to "5".
Just tossing that in if you find you can't see well... and seeing is EVERYTHING in welding.
