Old 07-11-2010, 05:15 PM
Revved's Avatar
Revved Revved is offline
Default Good source for Stainless Brake hardline?
Anyone know a good source for 3/16" Stainless steel brake hardline?
Getting ready to bend up a system for a build and all of the local spots that used to carry have gone out of business or no longer carry. None of my wholesale accounts have any sources either.
Old 07-11-2010, 05:25 PM
MODO Innovations's Avatar
http://www.classictube.com/
They will sell it in bulk or cut it to length for you. I bought some in 1/2" years ago for a project.
Shannon
Modo Innovations
940-391-9002
Old 07-11-2010, 07:22 PM
jski67's Avatar
jski67 jski67 is offline
I bought my tubing from McMaster Carr.
Old 07-12-2010, 12:04 PM
Revved's Avatar
Thanks for the replies guys...
Honestly, I hadn't even thought of checking McMaster-Carr. I guess it makes sense since they have every other nut,bolt, and piece of hardware known to man.
Old 07-12-2010, 03:10 PM
Apogee Apogee is offline
Whatever you get, be sure that it's fully annealed .028" wall 304SS tubing so that you can flare and form it well without too many issues. If you're not set on using stainless, Brakequip offers a copper-nickel alloy tubing that is much easier to flare and form than stainless and is almost as corrosion resistant. You can polish it if you're after that look.
Tobin
KORE3
www.kore3.com
Old 07-12-2010, 04:30 PM
Revved's Avatar
Tobin
KORE3
I just jumped on their website. Is that the "EZBend" product you were referring to?
Old 07-12-2010, 06:37 PM
jski67's Avatar
That's the type of tubing I used...it wasn't too bad to bend, but you will need a good flaring tool...my cheapy tool from Jegs broke after two flares.
I ended up buying a Rigid and it worked perfect.
Jason
