Old 07-31-2010, 10:07 PM
DRJDVM's '69's Avatar
Default Exhaust clearence
I went back and forth on long tubes vs shorties and decided to try the longtubes.....the shorties were almost as much $$ and only came in 1 5/8.....
I bought some TTI headers for the Cuda.......which I cant return since I bought them uncoated...... and my concerns held true. Since we channeled the k-frame......which moved the motor up about 1.5 inches..... the collector flanges hit the floor. This is why I had considered the shorties
Since I cant return them anyway, I cut off the collector flange. With no collector flange the collectors get as close as 1/4 inch to the floor. So....looks like I'll have to cut some more floor....oh joy, more work..... make one change and it snowballs......
So....when I make the plan for the floor....how much space should I try and get between the floor and collector? I dont want to raise the floor alot and destroy my leg room, but I also dont want to cook the floor either....so I'm looking for some "try and get at least" ideas.....
The headers will be coated and I can alway wrap some areas too....
Old 08-01-2010, 06:40 AM
You must be exhausted....
Old 08-01-2010, 07:45 AM
You could taper your collector right away into an oval pipe so you would have a minimal amount of floor mod to do? Spin tech makes all kinds of transition pipes. It also keeps more ground clearance if the car sits low.
Old 08-01-2010, 10:12 AM
Greg made a funny.....
Heres what I got....
Its closer than the pix make it look....probably 1/4 inch...in some places not enough to get my finger between the collector and floor
Old 08-02-2010, 06:28 PM
rwhite692's Avatar
Ned I would try to get about 1" of clearance...any closer than that you are probably into carpet-melting territory (just my opinion based on past experience...YMMV)
For added safety margin you could install a piece of radiant heat shield (the aluminum dimpled type, mounted on small standoffs) or, a material such as this:
http://www.heatshieldproducts.com/in...eat_shield.php
Project update thread here:
My Lateral-G Page
My Shop Build:
Old 08-02-2010, 06:43 PM
If I was as smart as Ned -- I'd just put some dumps straight off the header and forget about all that weight and heat from that stupid exhaust stuff. It's California DUDE... anything goes!
