Closed Thread
Old 08-05-2010, 08:26 AM
GM Muscle's Avatar
Default 1969 camaro- pro-touring project
Here's the build thread
https://lateral-g.net/forums/showthread.php4?t=24122
Located just north of dfw
$21,000
Driveline-
6.0L with 67K miles
Edelbrock cam and dyno matched performer rmp carb'd intake and matching bee hive springs
ARP rod bolts
hooker ceramic coated long tubes
speed demon 750 carb, BG fuel log
aluminum radiator with 5200cfm fan
4l80E trans
custom acc bracket setup with remote resevior power steering tank
Ford 8.8 rear end with 373's and disc
caprice fuel tank with an internal baffle
front suspension-
speed tech upper and lower a-arms
Qa1 shocks, afco 650lb springs with adjustable spring cups
hotchkis 1 1/8" hollow sway bar
Iroc fast ratio steering box with upgraded steering joint instead of a rag joint
ls1 front disc brakes with slotted and cross drilled rotors
wilwood 7/8's master and 3/16" lines w rear adjuster
19x8.5"front wheels with brand new tires
19x9.5 rears with used tires
car in general-
Gm red paint with a pinch of blue pearl
all trim is flat black
bumpers have been smoothed and painted to match
1/2 height body bushings
shaved wipers, rear body panel and deck fill panel
faux flush mount glass
what i needs to be finished-
rear suspension(has stock leafs)
trans controller
interior (has an interior but i wouldnt reuse it) carpet is good, rear seat is good. front seats are ok. you might be able to get away with some door panels and a dash pad if youre not too picky
some basic wiring and plumbing(fuel, water, alt, starter)
basically im just out of time and money
'69 Camaro- Daily Driver
'70 Chevelle- Project
Old 09-08-2010, 07:43 AM
GM Muscle's Avatar
bump for september
Old 09-11-2010, 12:54 PM
GM Muscle's Avatar
I would also concider trades for a running/driving tri-5 or a 67 nova
Old 09-11-2010, 04:24 PM
tmadden's Avatar
tmadden tmadden is offline
I hope it goes to a Texas driver. I sent it to a friend I hope he buys it.
Old 09-11-2010, 06:33 PM
dropit69 dropit69 is offline
please hurry up and sell that thing soon..lol....its so tempting and i even have a friend in Gunter so could stay there and pick it up but damn i have too many now..great price someone will get a killer ride..
Darrin
1971 Camaro
1971 Camaro RS
1973 Camaro RS "Dreamsicle"
1969 Camaro Coupe
1969 Camaro Convert -Pro-Tour build
www.fquick.com/dropit69
Old 09-18-2010, 08:32 AM
scuby22 scuby22 is offline
Hi, I was interested in your car, but having a very difficult time getting hold of you. Please contact me.
Closed Thread
