Old 12-23-2005, 11:05 AM
dplenzig's Avatar
dplenzig dplenzig is offline
Default DSE mini-tub kit and shocks --no tubs
I ordered a mini tub kit and put the tubs and crossmember in. I have decide to go with the 4-link and no longer need the rest of this stuff. It is all brand new and never used. I also have the mini tub shocks for this set up.
Rear upper shock mounts
offset schackles
leaf springs--2" drop
urethane bushings for springs
adjustable leaf spring pads
lower shock plates
u-bolts
dvd and instructions
koni mini tub shocks
$800.00 for everything
http://www.detroitspeed.com/RearSuspension10.html
Daren
Old 12-23-2005, 11:21 AM
Good luck with your sale Daren. Did you figure out how you're going to convert that crossmember?
Old 12-24-2005, 09:18 AM
Datsbad's Avatar
Datsbad Datsbad is offline
I was wondering the same . If you use the diagonal cross member in the car you cannot use there 4 link kit .
would you consider selling just the rear mini tub shocks ? I could use them !
""DEMON"
6.1HEMI/TKO 5 SPEED
CCW Black edition/BFG tires
Mini tub/AIR Ride
RMS Suspension
CURRENTLY FOR SALE !!!
Old 12-24-2005, 09:24 PM
dplenzig's Avatar
I talked to DSE and they have added the 4-link crossmember to the other one on some cars they have converted. I will have to wait until I get the instructions with the correct measurements before I decide exactly how I will do mine.
I would like to try and sell everything as a package for a couple days, before I split stuff up unless I get enough people that want different stuff.
Daren
Old 12-25-2005, 05:42 AM
Datsbad's Avatar
I would be very interested in the rear shocks . keep me updated . thanks , [email protected]
Daren
""DEMON"
6.1HEMI/TKO 5 SPEED
Mini tub/AIR Ride
RMS Suspension
Old 12-25-2005, 11:16 AM
hotroddr hotroddr is offline
I would be interested in the shackles and upper shock mounts if you want to split things up
68 firebird
66 Suburban
Dmax GMC
