Old 11-11-2010, 06:34 AM
Xplosive Performance's Avatar
Xplosive Performance Xplosive Performance is offline
Default C2/C3 Handling & Steering Package
Its that time of year to be driving that Vette
Make it even more fun to drive with this great package we have put together for you
Name:  Copy of Copy of AR-09C350-1001.jpg
-Arms
2 QA1 Coilovers Shocks
2 Upper Shock Mounting Brackets
Spanner Wrenches
Complete With Ball Joints
Uppers
• 6 Degrees Positive Caster for Improved Highway Stability
• Light Weight, Super Strong Chromoly Steel Construction
• Delrin Bushings
• Gloss Black, Long Lasting Powder Coat Finish
• Pre-Assembled
• Van Steel Limited Life Time Warranty
Lowers
• Light Weight, Super Strong Tubular Chromoly Steel Construction
• Designed For the Semi-Coil Over Spring Conversion
• Delrin Bushings
• Pre-Assembled
Van Steel, an industry leader in Corvette Suspension and Brakes, has ready for delivery, light weight, front upper control arms for the 1963-82 Corvette. Realizing most Corvettes drive on radial tires, Van Steel has designed this arm with 6 degrees of positive caster for premium highway stability.
63-82 Tubular A-Arms W/Coilovers 450# Springs- Car Set
Corvette Steeroids - Feel The Road! Steeroids™
Offers Improved Steering Feel -
Recirculating ball steering is vague and unresponsive, especially "on center".
Control is greatly enhanced.
Steeroids Offers Quicker Ratio -Steering racks offer quicker ratios. Steeroids™ power kits yield approximately 2.5 turns lock-to-lock (~2.9 for manual).
Steeroids are the only kits with adjustable tie rod ends to prevent bump steer - keep your car grounded and avoid darty behavior by keeping your alignment (bump steer) curves in check.
Steeroids Are Lighter Weight -Compared to the stock steering system.
Steeroids Offer Bolt On Installation -Absolutely no welding, or drilling. Installs with basic hand tools in approximately 3 hours.
Stock Pump Used -Existing or readily available power steering pump and brackets can be used.
Steeroids Come As A Complete Kit -All necessary parts are included with the exception of the power steering pump.
Parts Included With Steeroids: Rack and pinion
Adapter brackets (powder coated black)
Adjustable tie rod ends (Self cleaning & lubricating, teflon lined).
U-joint assembly
Power steering hoses
Misc. fasteners (grade-8)
Corvette Steeroids for Small Block Installation 63-66 Corvette SB - Power
Bought individually you would spend $3095.99
We have combined these two great products in a great package
for $2795.95
You must call us toll free or PM to order and mention Lateral-g
Bob Brown
XP Motorsports LLC.
Xplosive Performance Inc.
[email protected]
AIM: CH3NO2fun
www.xplosiveperformance.com
