Old 01-09-2006, 03:42 AM
Damn True's Avatar
Damn True Damn True is offline
Default How to incorporate a push to start button?
Id like to find some way to not have my keys wagging back and forth across my dash ('68 Camaro). I dig the idea of an ignition switch in a cubby in the console and a push to start button (ala Honda S2000 or Lexus) in place of the ignition switch on the dash.
Anyone done anything like this?
Have suggestions?
Have a schematic?
Muchos Mahalos!
Old 01-09-2006, 05:51 AM
D Rock D Rock is offline
I plan on doing this with a S2000 starter, I have no information on it yet however.
Old 01-09-2006, 06:56 AM
B Schein's Avatar
B Schein B Schein is offline
Shay Campbell’s old car has a s2000 push button. I believe I remember him saying it was rather expensive to do. He also said you cant get the pig tail from the dealer you will need to get it from a salvage yard and he had to get the wiring schematics from a Honda dealer. I believe he put the ignition switch in the lighter position in the ashtray.
Brian
Old 01-09-2006, 03:59 PM
4mm 4mm is offline
It's rather easy, look at the several kits for sale below with prewired harnesses.
http://motors.search.ebay.com/push-s...tonQ29Q2bs2000
Old 01-09-2006, 09:21 PM
Tim Baillie's Avatar
Tim Baillie Tim Baillie is offline
You can do it with a push botton of any kind and a $3 relay..............don't spend huge money on it.
www.hotrodderjournal.com
Old 01-09-2006, 09:50 PM
Damn True's Avatar
I'll be the first to admit that I am electricly challenged. Would it be possible through the use of a latching relay to have it push to start and push to stop using the same button?
Old 01-09-2006, 10:32 PM
Yep, however use the latching relay to trigger other relays as the latching ones aren't that heavy duty and will burn out if you pass that much current threw them. Use them to triger Bosch or Potter 40 amp relays.
Old 01-10-2006, 08:52 AM
Damn True's Avatar
I think I get it, but I'll need a schematic to do it.
Old 01-10-2006, 09:15 AM
TravisB TravisB is offline
I am putting one in my chevelle out of a honda. But I am also electrically challenged
Kenny Davis Hot Rods
Old 01-10-2006, 12:00 PM
69MyWay's Avatar
69MyWay 69MyWay is offline
A fellow at my work is a S2000 guy.
He said a great place to get the parts for this conversion is www.hardtopguy.com
