Old 12-22-2010, 02:53 PM
BANKO's Avatar
BANKO BANKO is offline
Default How To: Isolate Exhaust from frame cutouts?
I like how AME frames have nice exhaust pass-throughs for 3" exhaust tubing.
http://artmorrison.com/maxg.php
I was wondering how you guys have mounted your exhaust to prevent rubbing and vibrational noise to the frame when using these cutouts. I'm assuming you could do this by rigidly mounting the exhaust to the frame just behind the cut-out or using a high-temp elastomer as a damper.
Old 12-23-2010, 12:22 PM
Silver69Camaro Silver69Camaro is offline
Give our sales guys a call. They've seen it all...
Matt Jones
Mechanical Engineer
Art Morrison Enterprises
Old 01-02-2011, 05:07 PM
JRouche JRouche is offline
I have an art morrison frame, but made my own cutouts, they were not offering it when I bought mine, lil behind
I drilled (I think the size is correct, it was 12 years ago) 3.5" holes and welded in some 3/16" wall pipe. Then used some silicon sheet in between the pipe and my 3" exhaust tubes. It was a tight fit. And to be honest, I dont know if it helped with sound. My car is too noisy. But the thing with car noise is you have to tackle every point of noise and whittle it down. It will keep the metal on metal noise down. And the silicon sheet will hold up to the heat. JR
Old 01-02-2011, 06:14 PM
SDMAN SDMAN is offline
A/M frame here as well. We have done many 'special' modifications to my Max-G frame to get it the way we need it. One was to make room for bigger exhausts. 3" simply doesnt cut it on a big inch boosted motor. So we modded the cutouts in the front to take a 4" EQ round oval pipe header to muffler, and the rears to take a 3.5" EQ round oval. Once the tailpipe curves up we convert to 3.5" round. My motor is mounted on a front and rear plate, so no real movement. The custom tube headers have the oval collector as well.
Old 01-03-2011, 10:57 AM
BANKO's Avatar
Default Great ideas guys...
Thanks for the help....
@Silver69Camaro, I'll be sure to call and find out what you recommend, it is amazing how many accessories you guys offer at AME!
@JRouche, do you have any pics of your car, I'd be interested in checking it out.
@SDMAN, great idea about the use of motor plates, I also like your take on running your collectors to an oval cross-section. What kind of engine will you be running, turbos or supercharger?
Old 01-03-2011, 11:08 AM
Ron in SoCal's Avatar
Another suggestion here - Chris @ JCG makes these awesome billet exhaust hangers. I was thinking of using them above the cutouts for proper exhaust tube placement. Hopefully they'll secure the exhaust well enough to prevent any rattling?
Ron in SoCal
69 Camaro in progress
Old 01-03-2011, 11:56 AM
Car is very low, so nothing allowed to hang below the frame. Engine is an aftermarket block Pontiac, 555ci with a Procharger.
Old 01-03-2011, 10:08 PM
I dont think I have any with the exhaust, Ill look in my photobucket. If there arent any Ill make some time to crawl under the car and take some shots.
My car wont EVEN be as nice as the stuff the other guys posted. Im not a builder, this is my first car work. So I tend to go on what I can afford and my limited skill set.
But I did know what I wanted. Mufflers stuffed up high and tight. Three inch mufflers and pipes and you cant see them unless you get yer knees on the ground. They are high and tight and NO heat transfer to the floor. And even though the pipes are in tight contact with the frame the silicon sheet keeps anything from making any metal to metal noise, I think LOL
Everything else is so loud. The car is in all metal, no door or window seals, no interior. Its a work in progress.
Lemme see if I have any pics. Prolly not much to see anyway, more than I described. And it wont be pretty, be forewarned JR
Ok, I dont have any pics with the pipes going through the holes that I could find. This pic shows the holes and the exhaust dumping out right before them, small turn downs. Im gonna have to raise the car to get under it for some newer pics.
