Old 01-01-2011, 11:28 PM
Motorcitydak Motorcitydak is offline
Default AWD front end parts
Im currently looking into making my car AWD, Im just having a hard time figuring out what parts would be good to run. Ive looked over that Camaro build website and the guy says he is going to use a Cadillac STS front diff and I think c5 knuckles and hubs then run custom half shafts.
I know that the c5/c6 knuckles and hubs are good pieces and that the front hubs can accept a shaft since they are the same as the rear ones. What I do not like about them is that the upper ball joint is built into the knuckle. I want to run nascar type arms that have the ball joints in the arms. Does anyone have a good recommendation for some front knuckles that I could use? Im going to run 18x10's w/ 6.6in BS and 315 30 tires.
What Ive also been trying to figure out is what type of diff is the one from the STS? Is it based on a Dana 44 or something like that? I found one locally I can pick up with 0 miles on it with a 3.23 gear for $250. Ive also read online that the STS-V comes with 320hp out of the box but can be brought up to 600 or so with mods. Would this diff be able to handle that kind of power? My car will be somewhere in the 4-500hp and tq range.
Old 01-02-2011, 11:42 AM
Really intresting project.Remainds me Stielow buildt Quadra Duce. I would really like to see more custom built awd g-machines.
Could you take the upper ball joints away and machine billet bushing with correct tapper in C5 spindle.
63 Z06
Old 01-02-2011, 04:01 PM
Well anything is possible but I really do not want to have to do all that just to get em to work. Especially with the price of em, I do not want to have to do anything else to make em work for me. I figure it would be best to keep looking for other pieces to use. One huge problem Im running into is that most auctions on ebay do not even show a real pic of the part thats listed, just a random stock photo. Id also like to get diagrams for the parts since so I could know the ball joint angle and check my scrub radius on paper
Old 01-03-2011, 06:33 AM
Ketzer's Avatar
Ketzer Ketzer is offline
I don't have an answer but like what you're talking about!
My current project is a 54 belair wagon with the complete Trailblazer SS frame and running gear. I don't know how strong the Trailblazer AWD set-up is but know that the guys at the strip are going 10's before breakage. That takes some serious hp.
I bet Marty would know, I think he is pretty well versed in GM AWD units.
Jeff-
Old 01-05-2011, 02:52 PM
Well after doing more looking around, I noticed that the C4 front knuckles look a lot like the C5/6 knuckles....except that the upper ball joint is not captured in the knuckle. Im sure that there are some dimensional changes in there too but it may work for me. I can just put some C4 hubs in there I think and run the front CV shafts to that.
Here is a C4 knuckle
http://cgi.ebay.com/ebaymotors/91-92...#ht_500wt_1182
That one has the hub area wide open, Ive also seen ones that are closed off. Could I just cut that hole open if needed?
http://cgi.ebay.com/ebaymotors/88-89...#ht_500wt_1182
and the C5 stuff
http://cgi.ebay.com/ebaymotors/1997-...#ht_2260wt_941
Old 01-06-2011, 09:22 AM
wellis77's Avatar
wellis77 wellis77 is offline
I love the direction you are taking this project. This is going to be great!
Old 01-07-2011, 12:23 PM
syborg tt's Avatar
okay so what is the car that you are converting to AWD
do a search for AWD Vette ( in Poland ) - tons of pics on the build
used a Syclone transfer case and syclone front diff
Upper and lower controls arms from Mike Lee at Race Proven Motors
Same arms that Troy used on the 49 AWD Delivery Sedan.
and yep the Quadra Duece was AWD from a Syclone.
marty-mj
Old 01-07-2011, 04:09 PM
exwestracer's Avatar
exwestracer exwestracer is offline
Coleman Racing Products makes a "build-up" front knuckle that is basically just a flat plate that you add ball joint bosses, spindle, steeering arms, etc. to. Combining that with a bolt-in S10 front drive hub should allow you to set it up however you want.
I can't see you wanting enough torque split to the front to blow up a later model S10 diff...but I could be wrong.
Ray Kaufman-Wyotech chassis fab instructor
Custom suspension design and consultation.
(Now 2) Big Block asphalt supermodified ('cause too much is never enough...)
Old 01-08-2011, 03:50 PM
Thanks for the replys guys.
Im resistant to use a transaxle because then that located the engine way forward in the car. I want it actually to end up being mid engine. Im planning to cut the firewall and push it back around 10 inches. Im not running anything under the dash board (HVAC) so I figure why not put the engine there.
i was concerned with cutting the closed knuckles open for strength reasons, I just was not sure if they were the same thing except one of em was cut by the factory and one was not.
I still want to run a 5x4.5 bolt pattern so any hub that I run, Im planning to have redrilled since most chevy parts ran 4.75.
Is the geometry of the s-10/blazer knuckle good enough to run in a car like Im building? Id really like to get the best and lightest parts I can afford.
Im not trying to use any special one-off parts for this build if I can afford it. The STS diff is made by getrag but Im not sure what size the ring gear is. The one I found has a 3.23 which should work out great for me.
The trans I want to use is the 545rfe 5 speed auto that comes stock behind the 5.7 Hemi which I also want to run. I have one sitting around rite now from a 4x4. Im trying to just bolt a gutted transfer case to it to send power to the front. The trans is rather large and heavy but at least all that weight will be behind the motor and very low to the ground, helping out weight distribution.
The car Im building is a '68 Dodge Charger. Its pretty much a bare shell rite now so I have a blank canvass to build from. Im obviously not doing a typical resto on it. This car is getting to most ridiculous parts I can think of. I have a 3 link rear full floating 9 inch already in place minus coilovers, watts link and sway bar. I just bought lower control arms which are chromo pieces from a nascar, uppers will come from the same genre. I want it to be built to excess in terms of performance. I want it to be an engineering exercise I can drive.
Ive seen that AWD Vette, it looked just a vette with the front end of an S-10 frame welded onto it. Its neat but not what Im going for. Obviously I want it to be as light as possible and have the best weight distribution I can build. The STS front diff is a very compact unit which will not take up much space and have minimal weigh impact. Then just the CV shafts that plug into what ever knuckle/hub I can figure out to run. One good thing to see is that the vette had iirc a 7.2 inch front ring gear which was able to live with all that power.
Ill look into those parts from coleman, thanks for the tip. The motor Im running will have 4-500hp/tq, I figure that the front end parts should be able to live with half of that. I see FWD cars with 300hp w/o many problems.
Old 01-08-2011, 04:20 PM
ProTouring442's Avatar
Isn't there an AWD version of the Chrysler 300? Perhaps there would be parts there worth looking into?
Shiny Side Up!
Bill
Never met a man with real talent who felt the need to deride the efforts of other.
