Old 02-15-2011, 08:34 AM
American American is offline
Default CPP & PSC Suspension Packages - Feedback
I'm still considering Hotchkis but am looking at Classic Performance and Performance Suspension packages as well.
CPP has their package with tubular arms, made here in the U.S. for 1599.00: http://www.classicperform.com/Store/.../6774PTK-1.htm
they also have the next stage with QA coil overs and rear QA shocks for 1999.00: http://www.classicperform.com/Store/.../6774PTK-2.htm
Sign up in their forums and post a few times to get another 5% discount.
Then there's PSC.
Stage II with springs, shocks, sway bars, KYB (can upgrade to others) and a full poly front end rebuild kit for 1150.00 (plus any shock upgrades) and free shipping: http://www.performancesuspension.com...oducts_id=6061
And Stage 4 with Global West control arms for 2148.00: http://www.performancesuspension.com...oducts_id=6067
PSC uses Hotchkis front coils and McCoy 180lb rear leafs, Hellwig bars, 1" and 1 1/8".
Lowered leafs are a bit more.. but the total with a poly body mount kit and full Stage II suspension package to my door with KYB shocks is $1335.00, pretty hard to beat. Maybe add a Pitman arm for $75.00 and the adjuster sleeves are $14.00 each.
Anyone use these suspension packages?
Brad G
Fort Worth, Texas
1969 Camaro
Old 02-15-2011, 09:22 AM
Sieg's Avatar
Sieg Sieg is offline
The Classic links didn't work for me.
I've been researching F&R components for my '69 for a few years. IMO Speedtech is currently the best overall value. One thing appears certain, price increases are coming.
Old 02-15-2011, 09:23 AM
Fixed the links.
Brad G
Fort Worth, Texas
1969 Camaro
Old 02-15-2011, 09:50 AM
Sieg's Avatar
One issue I currently have with my older and settled Global West leaf's is rear ride height. They're supposed to be 2" lowered but my car is easily 1-1.25" high. Reluctantly, I'm going to install 1" blocks and see what happens. The coil over set ups allow more ride height and spring rate adjustability, so depending on how important stance and handling is to you, factor that into the decision.
Old 02-15-2011, 09:55 AM
I really figure for my use that PSC's Stage II setup will be great. I don't really see the need for tubular control arms for this car and what I install will be light years better than what I have now. This car is more of a driver with a higher level of performance, my 327 only knocks down 425HP so it's not like I'm going racing anytime soon... just harassing the locals.
Now...when I get around to building my 68 that I want to build.. .that will be a different story. Stripped down, big HP, monster brakes and a no compromise suspension.
Brad G
Fort Worth, Texas
1969 Camaro
Old 04-28-2011, 04:51 PM
Finally getting back around to this after being clobbered by home renovation costs.
I have a set of adjustable Konis for the rear. I'm leaning towards PSC's QA1 Pro adjustable coil overs up front $499, their sway bars $180 ea, 2" drop leafs $270, a full poly front end rebuild kit $240, body mount kit $60 with free shipping (keep that in mind, this stuff is heavy). About $1450.00 to my door with the leaf mount kit/bushings, etc. Obviously you would need rear shocks so add that accordingly.
I'm thinking coil overs as I've read too many posts where guys are fighting front end clearance issues...too little or too much. Most folks that I've talked to said unless you are serious about tracking the car, etc then tubular arms are overkill and a waste of money. Yes, they look great... yes they will lower your unsprung weight but I'm not going to track the car unless it's the random club track day, otherwise I'm just looking for a solid handling car, not cutting edge race bred handling.
I don't want to spend more than about 1500.00 for suspension, rebuild kit, etc so this seems to be about the best deal for me.
Brad G
Fort Worth, Texas
1969 Camaro
Old 01-27-2012, 10:27 PM
sanman's Avatar
sanman sanman is offline
Default CPP stage 4
Then there's PSC.
Just had the stage 4 installed on my 67 Camaro, so far I love it. I may replace the coils for coilovers? Put in their 500 steering box also.
