Old 03-02-2011, 08:19 PM
6carmello8 6carmello8 is offline
Default Will this tire combo work?
This will be my last tire question..I promise
Will this set up work on a 1968 Camaro (it's mini tubbed)
255/35/18 Front
305/30/19 Rear
The biggest problem I had was matching a tire that has similar sidewall height.
Obviously if the sidewall height in the rear is slightly taller than the fronts, no biggie.
From my calculations the front side wall height would yield 89.25 mm in the front and the rear would yield 91.5 thus be a working combo for the street?
Is this correct?
Thanks.
Old 03-02-2011, 08:30 PM
kmart401 kmart401 is offline
I'm sure Frank will be along in no time to answer this one!! He's great at nailing these combos on first gen camaros!
Old 03-03-2011, 10:52 AM
JayR JayR is offline
Lateral-G Supporting Vendor
Good job on the homework. The sidewall differences are very slight and with a hair more in back, you'll be looking good. I'd like to hear what other 67-68 guys say but I imagine the 255 up front is going to be a little tight and you're going to have to do a little minor massaging and sacrifice a little turning radius but it should work.
Old 03-03-2011, 03:53 PM
Thanks for the reply but I hope you recalculated the sidewall height for me
I started a thread regarding front tire fitment on a first gen camaro onthe stock subframe and James OLC said he ran a 255/35/18 with GW control arms with NO rubbing, so I should be good.
Old 03-04-2011, 05:49 AM
GrabberGT's Avatar
I started a thread regarding front tire fitment on a first gen camaro on the stock subframe and James OLC said he ran a 255/35/18 with GW control arms with NO rubbing, so I should be good.
I've been looking at tire/wheel sizes for some time now and have in my notes that OLC currently runs a 275/35-18 which is 25.6 diameter with 3.79 sidewall. Though I have no camaro, the 255/35-18 would be a little on the small side for me with a 25" diameter.
In trying to keep the front as 85-90% that of the rear for balance, I've come up with the following combos:
Front Rear
245/40-18 285/35-19
245/40-18 295/35-19
255/40-18 295/35-19
275/35-18 295/35-19
275/35-18 325/35-19 (Red Devil and Z06 Standard size. I dream that this might fit my car one day.)
Chris
Its not a Vega!!!!
Old 03-04-2011, 08:06 AM
Ya, take a look. http://www.rimsntires.com/specs.jsp There's a little more sidewall in back than in front
Old 03-04-2011, 11:48 AM
Front Rear
245/40-18 285/35-19
245/40-18 295/35-19
255/40-18 295/35-19
275/35-18 295/35-19
Thanks for this info, you guys are awesome...gotta love the forums for this!
What an awesome calculator...very technical. I didn't come across this calculator when I was searching
Jayson, do you think this would be a good looking combo on a 68 Camaro? I suspect it will since Evade is running 18 / 19 combo and looks great. The 19 rear really fills the rear wheel well and the 305 will be nice and wide enough for some decent power.
