Old 03-17-2011, 12:28 PM
sweatnblood sweatnblood is offline
Default still getting vibration WTF
Ok so does anybody know of a good susp. shop here in san diego...I have a 73 camaro running a lt/ 6speed...so far I have replaced the U-joints...balanced and rebalanced the wheels...checked the drive shaft...they were checking the angle of the tranz/ shaft/ rear...and beat on tunnel enough to get the so-called proper angle but I still have a feak'n vibration after 70+ it's not coming apart but the rearview is buzzing and I'm just wanting someone that can drive this thing and pin point...thanks for any help
Old 03-17-2011, 02:31 PM
uk68327's Avatar
uk68327 uk68327 is offline
Just a thought, but have you re-checked your wheel aligment?
Mark
'68 Camaro
'93 Golf Rallye
Old 03-17-2011, 03:10 PM
Sieg's Avatar
Sieg Sieg is offline
When did it start? What has changed?
Does it do the same thing in gears 4-5-6 at above 70?
Just trying to isolate chassis or drivetrain issue.
It's pretty much a crapshoot without knowing the history of your car.
Possibly a brake rotor?
Wheel bearing?
Axle?
Old 03-17-2011, 04:04 PM
CFster CFster is offline
You had the driveshaft balanced? Also, is the driveshaft diameter correct for it's length and material?
'67 GTO - LS3, 4L60E, SC&C AFX Package, KORE3 C6 Z06, Boyds PT-09s
'67 GTO LS3 Swap
Old 03-18-2011, 01:13 PM
Well the shake will happen in whatever gear I'm in once I'm about 70+...I had all the suspension in the rear redone...it was off a little so they trued everything...at this point I was thinking a race shop that does autocross might help but not sure who in the area would be a good place to look for something like that...
Old 03-18-2011, 06:35 PM
nicks67ca nicks67ca is offline
I had a bad vibration after an t56 swap I did in my 67. I checked everything.....drive line angle, drive shaft, wheels, everything. I was using solid body mounts, with an 8pt cage, and a brand new performance trans mount. for some reason all that acted like a big tuning fork and once i swapped out the hard trans mount for a "stock replacement" my vibration went away. Not even a hint in the shifter. Its a pain but you'll get it. good luck.
