Old 03-23-2011, 08:57 AM
Ron Fox's Avatar
Ron Fox Ron Fox is offline
Default Butt Weld Vs Step Weld
Not sure where I heard this but is it true that if a panel is stepped (say a quarter) that in the future it's possible that the repaired area can be seen or that area is too difficult to be worked?
Is it best that certain areas of the quarter be butt welded and some areas be stepped welded (for strength purposes)?
I plan to use Full Quarters but wanted to put my question to rest.
Thanks.
Ron
1969 Firebird, 4-speed Coupe
Old 03-24-2011, 03:14 PM
NsaneHotrodz's Avatar
NsaneHotrodz NsaneHotrodz is offline
Question
Which area are you concerned with?
www.nsanehotrodz.com
Dewayne Morgan
[email protected]
Old 03-24-2011, 04:39 PM
Ron Fox's Avatar
Are you asking which area of my quarter? Well, if it's true, any area this is step welded being seen in the future.
Are there ANY AREAS of the quarter that should not be butt welded but stepped?
Can the area at the very bottom of the quarter (where the patch panel would go) be butt welded?
Thanks.
Ron
Old 03-25-2011, 04:33 PM
Thumbs up
I butt weld almost everything. When you overlap panels it makes it very hard to work the area and it can hold moisture.
DeWayne
Dewayne Morgan
[email protected]
Old 05-03-2011, 12:02 PM
senor_Camaro senor_Camaro is offline
if your doing qtr panels I would suggest butt welding if your doing just skins its cleaner and you wont have to use as much bondo to smooth everything out. it just depends on how your installing them are you doing full qtrs or just skins replacement?
Old 05-03-2011, 01:05 PM
Ron Fox's Avatar
At first we thought about just cutting out the rot at the bottom of the quarters and around the wheel opening and welding in patch panels. My builder suggested a step weld since it would be stronger because of the angle at the bottom of the quarter.
Now I am going with full quarters (hopefully NOS quarters)
I like the Butt welds over the step welds.
Thoughts anyone??
Ron
