Old 04-15-2011, 02:53 PM
Black93GT's Avatar
Black93GT Black93GT is offline
Default '67 10 bolt or '98 LS1 rear???
I'm converting my 67 Camaro from 327/powerglide to LS1/T56. I was planning on using the LS1 rear and building a torque arm suspension.... but I'm hearing it may be weaker than the 67's 10 bolt.
So I pose the question which would be better/stronger? Both will require some fabrication and a new shock/spring set up. Eventually I'll upgrade but not with this tax return.
I never looked at it until yesterday, but it seems the LS1 brakes can be adapted fairly easily to the 10 bolt. Having the stock ratios, obviously I'd have to regear if I'd like 6th to be useful under 100.
Old 04-17-2011, 07:30 PM
64skylarkls1 64skylarkls1 is offline
Isn't there a huge difference in the width of the two axles? If so, that would greatly affect your wheel/tire combo and rim offset.
Old 04-18-2011, 12:23 AM
67 LS1 Vert 67 LS1 Vert is offline
The late model rear end you are looking at is not even close to the old school rear end strength.
Old 04-18-2011, 04:07 AM
19,69camaro 19,69camaro is offline
Another option you could look into are the 8.5" 10 bolts I think they started making them in 1971 there are millions of them out there and they are almost as strong as a 12 bolt. Check out this article http://www.chevyhiperformance.com/te...all/index.html
Old 04-19-2011, 09:09 PM
DEIGuy38's Avatar
DEIGuy38 DEIGuy38 is offline
That is what I am running in my car. There are different widths on those. I think the one that is the same width as a camaro is from 73-79 Chevy Nova, Oldsmobile Omega, Pontiac Ventura. I think the 2nd gen camaro rears are 1" wider per side. Depending on the wheels you are running, if they are from a late model camaro/vette you can run an impala 12 bolt rear because it is wider than the camaro by I believe 1 3/4" so you don't have to run spacers.
Guy
68 Camaro, LS1 T56, DSE Speed Kit 2, DSE Quadralink, DSE Mini Tub, Forgelines, Vintage Air, Dakota Digital, GM Tilt Column, Corbeau Seats
2012 Dodge 3500 4x4 6.7L Diesel CCSB
Old 04-20-2011, 05:07 PM
BadA** SS's Avatar
BadA** SS BadA** SS is offline
98-02 rear's are junk i blew mine up in my 99 ta and i wasnt even pushin much power to it
2000 SS M6 - traded
-torquer v.2, ls6 intake, headman lt's, SLP lid and bellow, ported ls6 oil pump, ls2 timing chain, true duals with bullet mufflers
1971 SS Camaro
-ls2 403ci (in the works)
1999 trans am
-painted ls6 intake, ceramic pacesetter lt's,SLP lid and bellow, full length true duals with bullet mufflers, Sam Strano lowering kit, ruff racing 278's, strange S60 3:73 gears, Zex 125 shot
