Old 05-02-2011, 12:10 PM
scherp69's Avatar
scherp69 scherp69 is offline
Default Speartech vs GM ECU
I'm still debating on whether or not I want to keep the VVT on my L92. Right now I'm leaning towards deleting it as I've been able to find some pretty good deals on stuff and it would be quite a bit cheaper to delete it. I found the LS376/480hp GM ECU for $885. I was also looking at the Speartech ECU's and see that they are $1395. What does Speartech do that makes theirs better to justify paying an extra $500? The only thing that I will need extra if I get the GM ECU are coil pack extensions, which can be bought for $100 and I'm sure that Speartech could lengthen the coil wires, but it's still another $400. Any thoughts on what makes the Speartech set up so much better? Thanks in advance.
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
Old 05-02-2011, 06:01 PM
ironworks's Avatar
Are you running an automatic trans?
Old 05-02-2011, 06:30 PM
scherp69's Avatar
No I'm running a TKO600.
Mike
New Gen Splitters
LS3 and TKO600
Old 05-02-2011, 06:41 PM
Doesn't the Mast ECM allow you to keep VVT as well? I'm not sure how it compares cost wise but the Mast piece would definitely be worth a good look.
John
'71 Nova (Build thread)
FFR Roadster
Old 05-02-2011, 06:45 PM
scherp69's Avatar
Yeah the Mast allows you to keep the VVT. Speartech and the GM one that I mentioned don't. I've been pricing it out and with the GM ECU, it's quite a bit cheaper to delete the VVT (probably close to $1000 cheaper). I'm trying to compare the two ECU in case I decide to ditch the VVT, which is the way I'm leaning right now. The Mast set up is more expensive than both of the ones that I mentioned.
The Mast set up is around $2500 for a WBO2 performance package which includes the ECU, a cam and springs. This would put me around 530hp. I would still need to get some water pump spacers which are $300 from Mast. I would also need to buy a DBW pedal.
If I delete the VVT, I can get a cam, timing chain, springs, push rods, timing cover with cam position sensor with harness and ARP bolts for $810 from Texas Speed. Their cams show close to 560hp.
Then I would need to get an ECU and the two that I've looked at Speartech and the GM L376/480hp one. DBW pedals are included with both.
Mike
New Gen Splitters
LS3 and TKO600
Old 05-02-2011, 07:22 PM
Yikes. Keeping my boat anchor seems less expensive everyday .
I've got a vehicle with VVT and have grown to like it. I've seen some good dyno numbers out of VVT setups as well. I think you have to put in some aftermarket limiters or something though when you start changing came profiles. I agree though that it'd be a tough call keeping it given the cost.
John
FFR Roadster
