Old 06-23-2011, 02:24 PM
70rs's Avatar
70rs 70rs is offline
Default Yes, more about hydraulic clutch.....
Can anyone tell me what vehicles from GM would be a good source for the hyd clutch cyl and remote res?
I want to use as many factory parts in my build as possible. I found a remote res system in a Fiero that LOOKS like it may work. But I don't know what bore size I will need to work the clutch properly.
Any ideas?
Thanks again guys!
Eric
Old 06-23-2011, 04:40 PM
BTTBSS BTTBSS is offline
What engine and transmission are you using? For LT1/T56 with pull style clutches a lot of guys use the late 1990's camaro master/slave. If you buy the master and slave as a package they should match. If sourced separately then you need to have the master sized to match the slave. Although if you have special needs like a short pedal throw you can use a larger diameter master to get the activation you need.
1996 Impala SS, Red Bow Tie Mod
Old 06-23-2011, 07:23 PM
70rs's Avatar
Thanks for the info. I am using a LS motor and probably a t56.
I get what youre saying about the slave being sized correctly. Your reply helps a bunch. Thanks again.
Eric
Old 06-28-2011, 08:39 PM
Z06vette's Avatar
Z06vette Z06vette is offline
I used all 4th gen LS1 hydraulics in my 69. Used speedtech's firewall mount & rod for the master to connect to stock 69 pedals. Scott
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
Old 06-29-2011, 12:05 AM
70rs's Avatar
Thanks Scott. I am currently looking for a 4th gen setup like you mentioned.
Eric
Old 06-29-2011, 12:43 PM
rchaskin's Avatar
rchaskin rchaskin is offline
Factory Camaro LS1 Hydraulics are GM Part# 12570277
$139 from GMPARTSDIRECT
Good Luck!
