Old 07-19-2011, 08:32 PM
scherp69's Avatar
scherp69 scherp69 is offline
Default Do I need to degree my cam
I plan on replacing the VVT cam in my L92 with a non VVT 3 bolt cam over the next few days. Do I need to degree it? I've read mixed reviews as to whether it is worth it. If I should, does anyone have an easy detailed way to do it? Not sure if it matters, but the cam I have is a custom grind that Patrick Guerra did for me. It's a Comp Cams cam done to his specs. Thanks in advance.
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
Old 07-19-2011, 08:40 PM
70rs's Avatar
70rs 70rs is offline
Hey Mike,
There is a lot of good instructional stuff on how to degree your cam.
If you really want to maximize the potential of your cam, you should degree it.
Call the guy that spec'd the cam, see how he feels about his design and the factory accuracy maybe?
If you are running a high lift/ tight tollerance with piston to valve clearance you really need to degree it.
Did you discuss checking your pushrod length after you install the cam? Your stock ones probably won't work......
Eric
Old 07-19-2011, 08:45 PM
I've never installed a cam without degreeing it.... It takes a very few minutes and there's really no reason "not to". It'd be like not checking bearing clearances or valve to piston clearances.... or the valve train geometry...
Once you put the motor together --- and if SOMETHING isn't right --- then you'd be laying awake at night wondering if the cam was the culprit etc.
Old 07-19-2011, 08:46 PM
scherp69's Avatar
Originally Posted by 70rs View Post
Hey Mike,
As to wheather or not you NEED to is open to debate.
You can install your cam as the mfgr suggests and be fine. If you really want to maximize the potential of your cam, you should degree it.
Yeah I saw there's lots of stuff out there on how to do it. Some was better than others. Also found lots of different opinions. I've actually sent Patrick an email to see what his thoughts are. Just wondering what most guys on here are doing.
Mike
New Gen Splitters
LS3 and TKO600
Old 07-19-2011, 08:58 PM
70rs's Avatar
Mike,
I had to edit my post. You should degree it. You're changing a bunch of things by eliminating the VVT. It would be easy, cheap insurance and as Greg said, you know its done right.
Eric
Old 07-19-2011, 09:09 PM
scherp69's Avatar
Thanks guys. I am probably doing to deree it, it's just one more thing I need to learn how to do...and go get a degree kit. Can I do it with the heads still on? I see some ways are done with the heads off.
Mike
New Gen Splitters
LS3 and TKO600
Old 07-19-2011, 10:09 PM
the last LQ9 I put together with a Pat G cam was off several degrees; not Pat's fault, it was the double roller timing chain and gears that I used, believe it was Edelbrock but don't quote me. I had to use the 3 degree keyway to get the cam to come in where it was supposed to be straight up, as tested by Pat on his machine.
Degree the cam...............
