Old 02-02-2006, 07:38 PM
dougs68ss dougs68ss is offline
Default 245/45/17 front?
i got these tires today. and they look huge for the front. im still waiting for the rims to arrive so i dont know really what to look for. im using 17x8 front with 5'' bs and rear is 17x9.5 with 5.75 bs front tire is245/45/17 rearis 285/40/17 hotchkiss suspension 2'' drop all corners. maybe im looking at my 15'' wheels on there now and just freakin out /// i thought i measured correctly for all ,,,, any body having issues on front with this size? please let me know......
Old 02-03-2006, 07:00 AM
Payton King's Avatar
Default fronts
I had a 17x8 on the front with a 245 tire without a problem, but i cannot remember the back spacing...4.75 stands out for some reason. If you have a 5 inch you can adjust with spacers if needed. I would be more concerned about the rear. I assume that you are running disc on the rear so the BS is correct. The 285 tire is going to be real tight, as in some fender lip mods. On my friends 68 conv the 275 is very tight.
Old 02-03-2006, 08:31 AM
jannes_z-28's Avatar
jannes_z-28 jannes_z-28 is offline
The fronts would fit precisely, you might as Payton say need some spacers. I have 17X8 with 4.875 BS and the tires just barely touch the frame when the suspension is loaded.
Jan
Jan Suhr
Stockholm, Sweden
'69 Camaro Z/28 LS1/T56
www.protouring.se www.carphotos.se
Old 02-09-2006, 10:53 PM
David Pozzi's Avatar
Just remember a 69 has 1" wider fender than a 67/68.
http://www.PozziRacing.com
Old 02-09-2006, 11:53 PM
rocketman's Avatar
i think you would be happier with a 35 series tire.i am putting 245/35/18 and 295/35/18's on my 69 vette.
Old 02-10-2006, 08:38 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
On my '68 I had a 17x8 with 5.25" bs, and a 255/40 17. Tire rubbed the frame some at full lock. No biggie IMO.
I don't think they make 35 series in these sizes in 17's. At least not when I was doing 17's.
Old 02-10-2006, 08:40 AM
ls67 ls67 is offline
Default thats right
I wish that someone would have pointed that out to me when I was researching tire sizes for my 67 I at first bought 17x8 x4.75 bs with 235 45 and they stuck out past the edge of the fender a bit. I got my info from guys that ran that set-up on 69s. I now am waiting on new 7inch with 5.00 bs and 225 tires.
fred
Old 02-10-2006, 09:23 PM
WicKeD_SS's Avatar
WicKeD_SS WicKeD_SS is offline
Hey whats going on? Ok, I have a 67 camaro with nothing done up front but 2 in drop springs. I am getting ready to buy rims, can I put 17x8 on the front without them sticking out past the fenders? If so What bs should I order. Any help would be sweeeeeeeet.
Thanks for your time!
WicKeD
Old 02-13-2006, 09:00 AM
MarkM66's Avatar
Going to have to ditch those drop spindles if you want to run a 8" in the front. Drop Spindles that I've used on a 1st gen allow about 4.25" bs max. I tried 4.5" on a '69, and had to grind the tie rod some to clear. That's not enoguh bs for an 8" wheel to fit.
Old 02-13-2006, 09:53 AM
camcojb camcojb is online now
Many have used that size combo on the fronts of 67-69 Camaros with no problems. Have not tried them with dropped spindles though. I'd think they'll be fine unless your car is super low.
