Old 08-27-2011, 05:55 AM
speedshftr speedshftr is offline
Default total ls cost conversion ?
can anyone guess how much a total conversion would cost.?nothing fancy just basic stuff
Old 08-27-2011, 07:26 AM
Cris@JCG's Avatar
Cris@JCG Cris@JCG is offline
It depends on what car & manual or automatic trans..
Shop for pull out motors..
Cris Gonzalez
Old 08-27-2011, 08:47 AM
DarkoNova DarkoNova is offline
Banned
Depends on if you can find any deals, really. And how many miles you prefer the engine to have. Lower mileage aluminum engines = big bucks.
I found an LS1 out of a 2002 Camaro with 40,000 miles and paid $2500 shipped.
$100-ish for mounts
$500-ish for harness mods
$300-minimum for fuel system mods
Then there's the exhaust system that needs to be modified, possible driveshaft lengthening/shortening, etc.
If you do the bare minimum, like just sump your tank and run a C5 fuel filter/regulator, use the stock exhaust manifolds, etc, it shouldn't be all that much more than a cheap SBC rebuild. But I'd say set aside a good 3-4 grand, minimum.
BTW, there's deals out there especially in this economy. That 40,000 mile LS1 I had? I had to sell it last year when I lost my job. Someone picked that thing up for $1500.
Old 08-27-2011, 10:42 AM
kochevy67's Avatar
kochevy67 kochevy67 is offline
That is a hard ? to answer without additional information like make of vehicle, carb or efi, etc.
Old 08-27-2011, 09:27 PM
realcoray realcoray is offline
On ls1tech there are posts about doing it for ~1500$ including engine (truck 5.3). The plates you can make, the harness you can modify yourself etc.
Old 08-28-2011, 12:13 AM
Jgpclone's Avatar
Jgpclone Jgpclone is offline
from 5k to 7k
from a to z and thats nothing fancy
Hi my names is danny and im a "hp junky"
2006 tbss stock dd
1969 camaro project
2004 scsb silverado joe gibbs clone
Old 08-28-2011, 07:31 AM
zmaniac's Avatar
zmaniac zmaniac is offline
I'm currently doing an LS Swap in a Chevy ll, I'll be 5k into it when I'm Finished.
Old 08-28-2011, 11:38 AM
almcbri's Avatar
almcbri almcbri is offline
LS1 with 63K $1500
Trans: T56 $1000 + $600 in upgrades
new Z06 clutch kit $400
slave cylinder & reservoir & line $189 ebay
Crossmember: re-worked stock TH400 x-member + new mount $15
Conversion Motor Mount Plates with 327 motor mounts: $35 ebay
Oil Pan Modification and p/u extension: $100 local welder
Lokar LS1 throttle cable and gas pedal $130 ebay
Dynatech headers $367-$430 (used a jegs discount code)
Dakota digital vhx gauges $667-$730 (this kit comes with all the sensors)
Wiring Harness and computer www.chevythunder.com $475
Walbro 255 fuel pump $70
misc. fuel lines and fittings $115 jegs
hard lines $100
99+C5 fuel filter/regulator $35 rockauto
stock LS1 radiator and fans $150-$250
radiator hoses, overflow tank
power steering hoses $75-100
ac bracket kwik performance $210
fuel tank $60 in my 94 caprice tank or spectra $400
shorten driveshaft $100-$200
misc. bolts $75
I would say and easy $5000 on a budget with a T56 and stock a motor
$4000 or so with a 4l60e on a budget with a stock motor
1968 Camaro LS1/T56, Hotchkis Springs, Tubular Arms, AFCO sway bar, C5 brakes, VWW 18" V40's http://s14.photobucket.com/albums/a3...1968%20Camaro/
Old 08-30-2011, 10:20 PM
Musclerodz's Avatar
without penny pinching, figure $5k plus motor and tranny components. If you really shopped and could do all the work, used a 5.3 and 4 speed auto, you might be able to do the whole thing for $5k
Mike Redpath
Musclerodz & Customz
facebook page
Old 09-19-2011, 12:28 PM
94snglturbo 94snglturbo is offline
man i wish it was that cheap for me ls2, fully built 4l80e, custom built turbo kit, speartech harness oh ya..
5k seems like a good number tho if you dont go all out. my speartech harness was 1400$ by itself
