Old 08-31-2011, 10:10 PM
scherp69's Avatar
scherp69 scherp69 is offline
Default How do I replace lower door hinge arm rivet on a 3rd gen Nova???
I'm going to be ordering all the parts to rebuild a set of stock hinges. I also want to replace the lower hinge arms, but I'm not sure how to reinstall the arm rivets. Here's the part I'm talking about: http://www.classicindustries.com/nova/parts/hc241a.html I can't use a press since I'm using 73-74 doors and will be using half of hinges which are welded to the door. The arm is on the part of the hinge that is welded to the door. Is there some type of tool that I can use? After doing some reading, these same rivets are used on first gen Camaros.
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
Old 09-02-2011, 11:14 AM
scherp69's Avatar
Here's some pics of the area I'm talking about. Hopefully they will help. I was reading that GM used some type of press at the factory and that's what gave it the cuts. The more I look at it, once the old rivet is gone, is there any reason I couldn't just weld the rivet to the hinge. It doesn't turn anyways, it's just there for the arm to swivel on. Here's the pics:
Mike
New Gen Splitters
LS3 and TKO600
Old 09-02-2011, 01:07 PM
70rs's Avatar
70rs 70rs is offline
I don't see any reason why you can not weld it Mike. As long as it moves freely like original, it should be fine right?
Eric
Old 09-02-2011, 04:53 PM
DarkoNova DarkoNova is offline
Banned
Can you do a writeup on it when you do it? I gotta do the same thing to my 69.
