Old 10-03-2011, 06:35 PM
orangevert's Avatar
orangevert orangevert is offline
Default Shop line epoxy primer question
I'm going to be using shop line epoxy primer? 2-1 but how much reducer should I use?
New to spraying auto paint. Just spraying the subframe and under the car, So I figure these are the area's to learn..
Thanks Kirk
Kirk
67 Convertible LS7 BBC 542HP.540 TQ
400 Turbo, 12 bolt posi, 13"12'' CPP Disc, Hotchkis connectors, belly pan.. Hush matt. 3" mandrel bent and load of other stuff.. More a show an Go..
Old 10-03-2011, 06:58 PM
NovaBlue71's Avatar
NovaBlue71 NovaBlue71 is offline
If you haven't bought the shop line epoxy do your self a favor and check out Southern Polyurethanes epoxy primer. Hands down some of the best epoxy you will ever use. Joe
Old 10-03-2011, 07:26 PM
Autokraft's Avatar
Autokraft Autokraft is offline
Supporting Vendor
Autokraft.org
Yep listen to Joe on this one. It is some good stuff
Autokraft
Old 10-03-2011, 07:40 PM
elitecustombody's Avatar
PPG says you can add up to 10% of acetone to already activated primer.
http://www.bapspaint.com/docs/psheet...line/JP370.pdf
I would never use acetone or lacquer thinner for thinning anything, just for cleaning .
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 10-04-2011, 05:29 AM
orangevert's Avatar
Thanks for the thread, I'm going to be needing a front fender,So I'll be PM you in a month or so.
Thanks Kirk
Kirk
Old 10-04-2011, 05:26 AM
orangevert's Avatar
Thanks for the reply, I already bought it. My plan for this product is for subframe and bottom of the car.
Thanks Kirk
Kirk
