Old 10-24-2011, 05:16 AM
Restocreations's Avatar
Restocreations Restocreations is offline
Default 1967 Mustang 03 4.6L SVT Terminator swap
This build has taken 3 years to this point. The 1st paint shop went out of business a few weeks after i dropped the car off and he took my $4,000 deposit with him. The second painter/body shop had the car for 18 months. I had the car for about 6 months after the car was finally painted, but soon realized that the shock towers had not been notched correctly and had to take the car to another shop to have the engine fit. I received the car back from the most recent shop in June, but due to two other builds, i could not resume work on the car until recently.
Anyway, here is the build from start to current progress.
1967 mustang fastback purchased in Spring of 2008. Bodywork started in late 08 and then modifications were made to engine compartment etc, starting in 09 when the 4.6L terminator motor was purchased.
Default August 2009
August 09
Old 10-24-2011, 05:18 AM
Default November 2009-February 2010
November 2009
http://i20.photobucket.com/albums/b2...e/IMG_0084.jpg
December 2009
January-February 2010
Old 10-24-2011, 05:19 AM
Default Feb-April 2010
March 2010
Old 10-24-2011, 05:21 AM
Default May-August 2010
May 2010
Suspension and Brakes
Floor pans Sprayed with Lizard Skin
Side stripes applied
Taillamps and back up lights installed
April 18th 2010.
Wiring from The Detail Zone
Old 10-24-2011, 05:26 AM
Default October 2010-June 2011
This is the point where i stopped and took the car to the 3rd shop to have the shock towers notched further back, the intercooler, radiator, reservoirs, etc installed, have the headers fit, etc. Initially the overpriced RRS notching kit was used, which probably would have been fine, but the first shop installed it incorrectly-they did not follow the templates i provided and the towers were not notched far enough. In hindsight, the motor should have been fit before the car ever even though about going into the paint booth and before the notching kit was welded in place....live and learn. In addition, it would have also been cheaper and smarter to simply buy plate steel and cut it out myself instead of buying the notching kit and paying for shipping from Australia-doh!
2003 Mustang Radiator and fan installed.
AC condensor from old air products. This is a great system and they really take pride in manufacturing high quality systems
Aftercooler AFCO double pass
09 CobraJet EGR Block off plate. It looked like it would fit, so i ordered it. Glad that it does.
Shock Towers notched further back for more clearance-total waste of time and money. If you are going to do this type of conversion, use a suspension like the TCI system that eliminates the towers
The engine mount supports had to be notched for exhaust header clearance.
The Ford Racing Driver's side exhaust header had to be cut and rewelded to clear the TCP power steering rack.
Engine compartment repaint. I decided to go with black for a better contrast since the engine is gray.
