Originally Posted by McssGmachine
I had hotchkis rear control arms on my Monte with poly bushings all around and the ride was very rough! Then I switced to currie's system and the ride is much smoother. I would highly recommed the spherical bushings.
I'm in the middle of a similar situation. I have stock uppers with poly bushings, and SSM lowers with delrins... Holy Suspension Bind Batman!
The new chassis has all Wolfe Racecraft rear arms with spherical bearings, and their spherical bearing that goes in the housing. With the springs removed, and the frame supported, I stuck a jack under the pumpkin to get the wheels off the ground. Everything articulated so smoothly and easily... I can't wait to drive it again when things work properly
