Old 01-07-2012, 03:32 PM
mexMan's Avatar
mexMan mexMan is offline
Default Bentfab is going to get one of this.
https://www.youtube.com/watch?v=ot0Cx...layer_embedded
That tool is like, super useful, and SO AWESOME! Really, bent, go get one! Check it out.
''Every car has a great quality, is not the hands that build it, is the dedication behind it.''
Old 01-07-2012, 04:20 PM
Okay -- that's some pretty cool stuff....
Not useful for our hobby... but if a guy was making 10,000 pieces of something that would be the tool to have!
Old 01-07-2012, 04:33 PM
I bent this one up yesterday - for the Wilwood MC to the front splitter...
Forgot to finish what I was going to say ---- which is --- that machine would have spit this out in 5 seconds instead of the hour I spent!!
Old 01-07-2012, 04:50 PM
KPC67's Avatar
KPC67 KPC67 is offline
That is cool.
Wonder what the programming for that is like?
Kevin Carter
Old 01-07-2012, 04:51 PM
mexMan's Avatar
I was thinking the same, it could work with AutoCAD or its own software.
Old 01-08-2012, 03:26 AM
MattO MattO is offline
Originally Posted by ratman67 View Post
i want to have sex with that thing...lol
Just be careful which end you get 'busy' with
"Anyone have a cork screw?"
"Yea, but you'll have to look away for just a sec..."
"I should have just started smoking crack. Its just as addicting and WAY cheaper..." --unknown
Old 01-08-2012, 12:33 PM
Greg, I'm impressed! That pretty cool work doing it yourself. What tools did you used?
Old 01-08-2012, 12:59 PM
Oh.... I have a few tools.... just not the skills to use them.
This is every RIDGID 400 series bender from 3/16 to 1/2".
The "KEY" to bending is to understand the markings on the benders.... which is what most people never bother to figure out! There are marks on the bender for 0* - 45* - right of center - left of center and 90*..... so it depends on where you measured from and to... and how you translate those "measurements" to the marks on the bender. So the 3/16" tube bender - for instance - has a 0* mark and the RADIUS is 5/8" (as shown on the bender) - if you use the 0* mark you have to SUBTRACT 5/8" (the radius) from every measurement.... because setting up at 0* will ADD 5/8" to make the bend... But if you just measure say -- 3" --- and you're going to bend a 90* --- just set your mark (the 3") on the 90* mark of the tool and it will do all that adding and subtracting for you!
Like most things - it's really just understanding the tools used... and measuring correctly. Trust me - after saying all of that - I've bent many thing two and three times.... because it only takes one wrong set up and bingo - you've bent the tube the opposite direction of where you wanted to go! Or worse yet make a perfect tube and then forget to put the tube nut/sleeve on before you flare etc.
Old 01-09-2012, 12:43 PM
youthpastor's Avatar
nice- yep good info- I think I am below the 50% mark now...another measurement you must understand....buy twice as much and throw 1/2 of it away as misguided bends. but practice makes perfect um or better
[SIGPIC][/SIGPIC]
CHRIS HOLSTROM CONCEPTS
http://chrisholstromconcepts.com/
Old 01-08-2012, 01:10 PM
So here's another trick --- note the "step" in this tube.... that's because I had to step over the frame rather than just drop straight down... to the tube comes from the master cylinder - bends 45 back to the firewall - then has to bend 45 to go "down" -- then the STEP out away from the frame....
To do that --- takes TWO 45's --- and those two 45's just need to be DOUBLE the amount of the step dimension. So I needed to step over about 3/4" -- so two marks -- 1 1/2" from each other - make a 45 bend -- flip it - make another 45 -- and you've stepped over 3/4".
If you have to step 3" -- then your marks are 6" apart.... and so on.
