Old 02-02-2012, 05:37 AM
Autokraft's Avatar
Autokraft Autokraft is offline
Supporting Vendor
Autokraft.org
Default Short Dual master cylinder?
Does anyone make a short master cylinder (dual resevoir) thats about 4 3/4 from the mounting flange to the end or less?
Space is tight and I dont really want to change over to a Wilwood or tilton tandem setup if I can help it.
Not much room between the firewall and back of the valve cover so I'm kinda limited
Autokraft
Old 02-02-2012, 06:40 AM
Payton King's Avatar
Default If you are speaking of
a dual master set-up with a balance bar, yes Wilwood makes the short masters with about an 1 inch throw.
If you are speaking of a tandum style, I do not know of anyone doing that.
You could probably move the master over and use a linkage like this.
http://www.moderndriveline.com/catal...ic_masters.htm
Peter is doing a 69 and the master was moved over and he is using a link like this.
Old 02-02-2012, 07:23 AM
Have you looked at a Viper master? Paul at Hydratech got me one for the Chevelle to gain exhaust clearance. It was at least an inch shorter than the GM style masters. Not sure of the overall length though.
Old 02-02-2012, 07:42 AM
Autokraft's Avatar
Supporting Vendor
Autokraft.org
I will check that out Jody.
Thanks!
Autokraft
Old 02-02-2012, 07:40 AM
Autokraft's Avatar
Supporting Vendor
Autokraft.org
Payton I am using a similar setup for the clutch already (not off set like that) but off setting the brake master would help out a ton so maybe a combo of both would be the ticket.
Autokraft
