Old 02-28-2012, 06:01 AM
Greg from Aus's Avatar
Greg from Aus Greg from Aus is offline
Default Best shifter for t56 Magnum into a 69 Camaro
Hi guy's,
Looking for choices.
Greg
Old 02-28-2012, 07:05 AM
Sieg's Avatar
Sieg Sieg is offline
I have the Hurst Blackjack on my Magnum, it aligns in the stock console well and shifts great but it's leaking out of the top ball, the issue IMO is assossicated with cutting out and reusing the internal Tremec rubber boot per their instructions. They say there may be an internal drain in the upper shifter housing that's clogged but I haven't had time to tear it apart and verify if thats the case.
Unless they've addressed the seal design I'd probably suggest a different design.
Old 02-28-2012, 08:10 AM
ErikLS2's Avatar
ErikLS2 ErikLS2 is offline
This is the one I'm going with: http://www.mgwltd.com/
Erik
69 Camaro
Old 02-28-2012, 03:20 PM
Blake Foster's Avatar
I used the shock shifter with a long hurst handle and LOVE it. it is mostly an arm rest when driving, stifts as fast as you want.
Blake Foster
www.speedtechperformance.com
Old 02-29-2012, 06:04 AM
Thanks guy's I will have a look at them.
Greg
Old 02-29-2012, 07:08 AM
EBMC's Avatar
EBMC EBMC is offline
Is that a lineloc button on your pro touring car? Once a drag racer, always a drag racer....
Steve Keefer
Old 02-29-2012, 07:44 AM
lol
no it is for engaging the SUPERCHARGER !!! DUHHH
Come on Steve
actually it is the reverse lock out.
Blake Foster
