Old 03-20-2012, 08:29 PM
John510's Avatar
John510 John510 is offline
Default Wheels don't fit brakes!
I spent a ton of hours today assembling my subframe and brakes only to find out that the Fesler (Baer) hub is too big to go into the hole on the inside of my Fesler wheel.
What do I do now?
Do I need to have my wheel taken apart and have the hole machined bigger?
[SIGPIC][/SIGPIC]
Old 03-20-2012, 08:36 PM
canrc canrc is offline
Hey John -- I had something similar happen to me with Asanti wheels (same as the fesler stuff) I had to have the wheel taken apart and machined and also had to modify the centre cap, I feel your pain it sucks! Maybe you'll have better luck than me and not had take apart the wheel.
_________________________
- Raj
'69 Camaro - Current Project
https://lateral-g.net/forums/show...ighlight=MAX-G
Old 03-20-2012, 08:40 PM
John510's Avatar
You would think they would make them bigger to fit the Baer brake kit they put their name on.
[SIGPIC][/SIGPIC]
Old 03-20-2012, 08:47 PM
Ron in SoCal's Avatar
Uh, yeah...same name on both! Dial 1-800-Chris-fix-this!
GL Bro
Ron in SoCal
69 Camaro in progress
Old 03-20-2012, 08:55 PM
Forgot to mention I have wilwood brakes not Baer -- good luck!
- Raj
Old 03-21-2012, 06:37 AM
Payton King's Avatar
Default What size rotors are you using? Rim Diameter?
Was looking at your pics and the calipers appeared to be high on the rotor...it may just be the angle. I assume the brake pads are at the top edge of the rotor when installed.
