Old 04-21-2012, 10:31 AM
billscamaros billscamaros is offline
Default Rear Gears - Summit vs. Richmond
I'm currently running a 3.73 rear gear in my GM 8.5 10 bolt with a Turbo 350 trans. I'd like to swap these gears out for something closer to 3.23 .... my daily commute is 60 miles each way and I want to drop my rpms a bit to make this an enjoyable drive.
My question is in regard to quality ... the Summit Racing gears (and install kit) are significantly more affordable than the Richmond gears (and install kit). Is this an example of 'you get what you pay for'? How do the Summit gears compare, and will I be happy with them?
Bill
______________________________________
1999 Camaro Z28 M6, some mods, 345K miles
1969 Camaro RS Convertible, 350/700R4, 3.73 posi rear, disc brakes
1992 Dodge Ram W-150 4WD, stock, 80K miles
2007 BMW 328xi, 110K miles
2002 Porsche 996, 6 speed, 50K miles
Old 04-21-2012, 12:37 PM
realcoray realcoray is offline
The thing with Summit brand parts is one of that one of summits name brand places makes their brand. There is a decent chance Summits ARE Richmond (or motive).
Old 04-21-2012, 03:18 PM
That thought crossed my mind. But I thought that I would toss it out here and see what insights I get.
Bill
Old 04-22-2012, 09:37 AM
samckitt's Avatar
samckitt samckitt is offline
I bought a brake proportioning valve a few years ago that is a summit brand, when I got it I took the summit sticker off 7 it was a Wilwood part.
Scot
86 Monte SS
LS2/T56 Magnum
Old 04-23-2012, 02:16 PM
ErikLS2's Avatar
ErikLS2 ErikLS2 is offline
When I bought my gears I called Drivetrain Specialists who I've had good luck with before. They said they've had the best luck with Motive's "Performance" line. These are a little more $$ than the regular Motive sets you get at Summit and Jegs. Not on the road yet but the setup was easy and the pattern is spot on.
Erik
69 Camaro
Old 04-23-2012, 07:06 PM
69x22's Avatar
69x22 69x22 is offline
Good luck with any of them. With aftermarket gears it is a hit and miss on whether they will be whisper quiet or not. Most of the time you can hear them.
Old 06-23-2013, 09:33 PM
Zspoiler's Avatar
Zspoiler Zspoiler is offline
Default Summit vrs Richmond Gears
I would n`t either. I have a 8.5 10 bolt in both my 1979 Z-28 Camaro (Supercharged Small block ,Super T-10 four speed) , 1981 El Camino SS ( 290 HP Crate engine ,Turbo 350 Trans) I run Factory GM 3:42 gears . Both cars have been my daily drivers at one time. Both cars run around 2500 rpm with a 26 tall tire. get around 20-24 MPG. The gears are very strong and are`n`t noisy. Like the Richmond gears .I got this recommendation from the owner of shop I had my 10 bolt rear end rebuilt at.
