Old 07-13-2012, 11:51 AM
Formula43 Wheel's Avatar
Formula43 Wheel Formula43 Wheel is offline
Default Formula 43 RAD5
One of our local customer's here in Detroit Al Sharp and his 67 Camaro with Formula 43 RAD5.
Formula 43 modular wheel center sections use a Rotary Forged process that results in a superior tighter, circular grain structure. The rotary forged center section begins life as a cylinder of billet. The billet is then heated and placed into a die in the rotary forging machine. The die spins the billet at 300RPM while the billet is pressed from above at a 5 degree angle. The material then flows in a circular pattern into the die. The new forging is then heat treated, quenched and aged to T-6061 standards. The end result is a rotary forged center section that has stiffer spoke dimensions, lighter weight and a quicker moment of inertia.
Old 07-14-2012, 08:53 AM
coolwelder62's Avatar
Very Cool.I wish I could have as many set's of wheels for my car as my wife has pr's of shoe's.
Old 07-16-2012, 07:45 AM
Don't we all!!!
Would need to build on an addition to the garage for a wheel closet!
