Old 08-19-2012, 11:41 PM
gnx7's Avatar
gnx7 gnx7 is offline
Default quietest gears for Ford 9"
I'm buying a used built HD Currie 9" for my Chevelle project and it has 3.90 gears. I want to swap in 3.25 gears for my turbo project.
What manufacturer makes quiet gears? I don't want any whine.
Old 08-20-2012, 12:49 PM
69x22's Avatar
69x22 69x22 is offline
Good luck with that one, it's a hit and miss with aftermarket gears.
Old 08-20-2012, 02:46 PM
badmatt's Avatar
badmatt badmatt is offline
........... seriously how much more quiet do you need LOL.
if you want quiet get them REM finished and run good fluid.
97 Sonoma "NERA": Pile O Sh*t. Literally.
Old 08-20-2012, 02:56 PM
gnx7's Avatar
I've had a number of 8.8" rear ends built and only use Ford Motorsport gears as they are quiet. Richmond gears in the 3:90 ratio whined like crazy. I asked my differential guy about it and he said that is what particular brand in that ratio does. He has been working on transmissions and rear ends for 35 years.
So that being said.... what gears are you guys running in your 9" that don't whine. There are a dozen manufacturers and I don't want to make that mistake.
Old 08-20-2012, 04:56 PM
Call Randy's Ring and Pinion.... (google 'em) and they'll know more about this than the average guy on the street (which is what you're asking here). Or call and ask Currie -- or Strange.... They all have lots and lots of experience.
Old 08-20-2012, 05:58 PM
badmatt's Avatar
the surface finish has a lot to do with this hypoid gears rub faces the smoother you get the finish the less noise you will have.
