Old 08-29-2012, 07:36 PM
chevmech1969's Avatar
chevmech1969 chevmech1969 is offline
Default Gulstrand mod. yes or no with my planned componets?
Ok, ive got my mind made up on certain upgrades to do to my 69 camaro. I am a little confused with my set of upgrades i want, if i need to do the gulstrand mod or not.
Upgrades
Chicane kit
SC&C Street-Comp AFX spindle and upper control arm kit.
and a set of ridetech lower control arms.
and of course all new steering and Hellwig Anti Swaybar
Any help or advice would be appreciated.
Johnson's Rod'Z
A man with few vices, has damn few virtues.-Benjamin Franklin
Old 08-29-2012, 09:15 PM
DEIGuy38's Avatar
DEIGuy38 DEIGuy38 is offline
call Marcus at SC&C he will have the answers
Guy
68 Camaro, LS1 T56, DSE Speed Kit 2, DSE Quadralink, DSE Mini Tub, Forgelines, Vintage Air, Dakota Digital, GM Tilt Column, Corbeau Seats
2012 Dodge 3500 4x4 6.7L Diesel CCSB
Old 08-29-2012, 09:41 PM
Sieg's Avatar
Sieg Sieg is offline
+1
Technically you can achieve respectable performance with Howe tall b-joints and tie rod ends with SPC uppers and stock lowers, with good shocks and proper spring rates. How much do you want to spend and what is important to YOU?
You can mod the stock subframe and lower control arms to reduce flex or buy SpeedTech or Detroit sub assemblies and roll with the players. Both will produce similar numbers on the clock the latter will give you much more to talk about when the key is in your pocket.
It somewhat depends on how much expendable income you have and how you want to use and enjoy Your car.
Driver, Show'r, or Tweener?
It's so easy to get wrapped up in the hype and lose perspective on your personal ideals...........
Thankfully up here in Oregon I don't have to keep up with the Jones' in California and I like driving it.
Figuring out the right combination for you and confirming it before your throw cash at it is a good portion of the entertainment value. Enjoy the ride.
Old 08-30-2012, 05:30 AM
+1
I'm not interested in a new sub. i spent quite a lot of time grinding the factory welds and rewelding the sub completely. filled all the holes i dont need, and found out i filled a few i did. woopsy.. i plan on driving my car. i do not have expendable income, im married with two kids. lol... i buy what i can when i can. the main reason for the afx spindle is the vette bearing packs and improved geometry the reason for the chicane kit is for the longer stroke shocks. im not just throwing good parts at it to say ive got them and not use them. i plan on driving the crap out of my car when its done. its been sitting for far too long. its my big push to get it penciled out and stick to my personal plan.
Youve made me rethink a few things. as i can get decent performance with saving some $ and later when i have more $ spend it on the afx spindles and lowers. gives me more $ for the rear which is a whole different animal.
Pondering.........
Thanks johnny
Johnson's Rod'Z
Old 09-02-2012, 03:19 AM
makoshark makoshark is offline
Another option is Ridetech's new TruTurn system. I installed the ATS/Chicane upper brackets, upper and lower tubular arms with double shear lower brackets, 5" stroke Ridetech single adustable coilovers and the TruTurn system. This setup rivals any aftermarket subframe and requires a moderate amount of fabrication.
Old 09-02-2012, 06:01 AM
Supporting Vendor
Before I get flamed and upset guys I provide parts to (sorry Blake), I have to say I'm writing this from 80% personal, 20% professional.
Chevmech, you stated you had 3 main criteria for choosing these parts, but that you were also on a budget (I'm in the same boat. . .though I build these parts for a living I do have a wife, a kid, and a bad car habit, so "bang for the buck" is always on the top of my list.)
1-vette bearing packs
-$175-350 for Corvette bearing packs (EACH)
-$60 for stock Camaro bearing kit
2-improved geometry
-$1200 for AFX spindles
-$350 for Ridetech spindles (or $1000 for TruTurn with spindles, you can see a direct comparison here: http://www.ridetech.com/store/tru-turn/)
3-longer shocks
-Chicane kit with Ridetech single adjustables is $945
-Ridetech single adjustables to fit a stock subrfame are $700
(since you would be using the same lower control arms the only thing the Chicane kit gets you is a double sheer upper mount. the suspension can only move between the bumpstops, so it doesn't care if you have long stroke shocks. If you were using a different lower control arm the Chicane kit would then provide the correct stroke.)
So lets say you buy these parts, and in a couple of years have to replace the hub bearings (so we can factor that into the price just for S&G's).
You'd spend $2495 on the parts you want now.
You'd spend $1760 on an equal performance option (this includes the TruTurn, so I'd say it's even better performance wise).
If price and performance are equal factors you could easily have an extra $735 to throw at the rear.
Skunk Werks
Ridetech
www.ridetech.com
Old 08-29-2012, 09:32 PM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
Upgrades
Chicane kit
With the tall AFX spindles, no G-Mod.
