Old 09-10-2012, 07:50 PM
73camarols1 73camarols1 is offline
Default DSE battery cables
I was looking at some DSE pics and I was just wondering why they run the neg battery cable all the way to the front with the pos cable? I see a lot of other relocation kits only come with a short piece of neg cable. Thanks Bill
Old 09-10-2012, 08:03 PM
brownz brownz is offline
From what I know you want to ground your car to multiple locations. So you want to grounf the engine, body ect to the battery so that they all have the same ground.
when I did the battery cables on my car I ran what DSE has but aldo ran one to the body in th trunk area and also on to the pass side cylinder head.
Hope that helps
Old 09-10-2012, 08:09 PM
You will get lots of opinions but I like the negative cable grounded to the drivetrain close to the starter instead of running through 40 year old sheet metal. A body to drivetrain strap is also recommended.
Old 09-10-2012, 08:24 PM
FETorino's Avatar
FETorino FETorino is offline
You and Herb Adams. Back in the 80s in his guide to making first gens handle he sold battery relo kits with full length cables for the -
Same reason you always see dim tailights on old cars, old sheetmetal often makes for a bad ground.
Rob in SoCal
Old 09-11-2012, 04:50 PM
Thanks guys. I know if DSE was doing it there was a good reason.
Old 09-11-2012, 08:56 PM
72Z/28's Avatar
72Z/28 72Z/28 is offline
Also DSE uses 2AWG battery cables instead of 1/0 or 1AWG. Is there a reason for that also?
72 Camaro RS:SOLD
68 Camaro:
